Valve cover
Old May 3, 2004 | 06:03 AM
Crimson490's Avatar
Default Valve cover
Is the valve cover the same for 96-00 civic? (excluding the si)
I sheared a bolt on the valve cover, and need one asap. No honda dealerships carry these in house (how lame!). If I go to a junk yard, I wanted to know ahead of time if I can pull one off of an older car - mine is a '00 EX.
Thanks!
Old May 3, 2004 | 06:08 AM
Crimson490's Avatar
Default Re: Valve cover (Crimson490)
or for that matter, how about a 92-95 civic?
Old May 3, 2004 | 06:19 AM
martini's Avatar
exactly which bolt did you shear off? Because I don't recall there being any bolts on valve covers....They all go through the valve cover from the head. Though I can't say that for your specific car for sure..
Old May 3, 2004 | 06:22 AM
Crimson490's Avatar
Default Re: Valve cover (martini)
you're right - the bolt goes through the cover and screws into the head - clamps the valve cover gasket.
Old May 3, 2004 | 07:11 AM
ykracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson490 &raquo;</TD></TR><TR><TD CLASS="quote">you're right - the bolt goes through the cover and screws into the head - clamps the valve cover gasket.</TD></TR></TABLE>
but then getting a new valve cover isnt going to help you. You will need whatever part of the head that the broken bolt threads into...
Also, I could be wrong, but I think that all of the SOHC valve covers are interchangeable.
at least I think.
Old May 3, 2004 | 08:21 AM
Crimson490's Avatar
Default Re: Valve cover (trboCIVICWRX)
Sorry, I wasn't very specific...I needed a new bolt that holds down the valve cover.
In any case, I just stopped over at the local junkyard and found some bolts off of a '98 4dr DX (specially equiped with robin nest and three eggs next to exhaust manifold). Same length and everything. This leads me to believe that at least from '96-2000, all trim levels (except si) use same valve cover bolts (short and long).
Best part is, I got them fo' free and today!
Thanks anyway guys!
Moto DC2
Dec 26, 2007 11:59 PM
Si_chRis
18
Jul 5, 2006 05:25 PM
fanta!
Jul 5, 2005 12:46 PM
JDM_lover03
10
Oct 19, 2004 07:06 PM
hatchii
Nov 29, 2003 08:07 PM
