do these sparkplugs look like there in normal condition...> ?
Old May 4, 2004 | 09:37 PM
TurboB18C1's Avatar
Default do these sparkplugs look like there in normal condition...> ?
Well i am running 850cc injectors with Hondata but at idle my car starts to lean out and then rich-ins it self out for a while and then starts to lean out again... > ? could this be my part throtle tunning i have the techedge wide band hooked up to the ecus 02 linear signal and it still runs lean.. on the plugs there is little bulid up but dont know what that is looks like oil? and looks of the plugs the car is runing rich..
did a compression test 203- 205- 191 -198 compression JE 9:5:1
Old May 4, 2004 | 09:41 PM
onePOINTsix's Avatar
Default Re: do these sparkplugs look like there in normal condition...> ? (TurboB18C1)
comp #s are fine, looks like your fowling plugs, sounds like a Cold idle enrichment problem. Or your running too cold plugs. Ether way those are pritty fowled
Old May 4, 2004 | 09:44 PM
TurboB18C1's Avatar
Default Re: do these sparkplugs look like there in normal condition...> ? (Sideout)
Heat range 7's on 10 psi those plugs had a stock gap of .044
Old May 5, 2004 | 04:06 PM
TurboB18C1's Avatar
bump
95DC2GS-R
Sep 24, 2009 11:04 PM
stockb18c
Jun 4, 2009 09:08 PM
bennyhonda7
Jun 21, 2005 12:49 PM
t3to4e
Dec 6, 2004 09:12 PM
b18bvudoo
Mar 31, 2002 10:28 AM
