how do you chip a p28
Old Apr 30, 2006 | 12:30 AM
JDM_EK_621's Avatar
Default how do you chip a p28
ok i have looked and looked i am just needing some pics or a web site on where some things go in the p28 ecu
I am taking the ECU to a computer shop here in town and they said that they would do it if i know right where every thing went.
then i just need to know what it takes to turn it in to a manual
i know where it is on the ECU but i donno what needs to be changed
Modified by JDM_EK_621 at 1:56 AM 4/30/2006
Old Apr 30, 2006 | 01:38 AM
JDM_EK_621's Avatar
Default Re: how do you chip a p28 (JDM_EK_621)
10 views and no help
bump
Old Apr 30, 2006 | 05:52 AM
NJIN BUILDR's Avatar
http://www.hondata.com/downloa...l.doc
http://home.mn.rr.com/keebler6....html
Old May 1, 2006 | 04:35 AM
NormanBates's Avatar
pgmfi.org
this website has ALL the info you need....Search button does work, right?
Old May 1, 2006 | 08:07 AM
JDM_EK_621's Avatar
Default Re: how do you chip a p28 (KillerAccord)
yea i know but every time i go to pgmfi.org it never pulls up i donno y
Old May 1, 2006 | 02:59 PM
http://forum.pgmfi.org/
Old May 1, 2006 | 04:12 PM
JDM_EK_621's Avatar
ok i got the chip in and everything
BUT i got it in my car and took it for a test drive everything was going good i hit about 65mph and then the car just shut off and then nothing i can start the car but it just idels for a about 3 sec then slowly kills its self i donno what it is im about to snap and sell it i have nad nothing but probs. i donno what to do anymore
Old May 1, 2006 | 08:37 PM
whatthehell1051's Avatar
that pic you have has not everything you need. post a pic of the computer now and ill let ya kno if it done right.
Old May 13, 2006 | 01:27 PM
JDM_EK_621's Avatar
Default Re: how do you chip a p28 (whatthehell1051)
ok well here is a pic after i chipped it any help
there is no place around here that will tune my car does anyone know where i can find some tuning software??
Old May 13, 2006 | 02:16 PM
that chip is permenit you can't remove it. you screwed unless you have someone remove it and then resolder it back. the idea of a chiped ecu is to be able to remove it and tune the chip so you have a really good tune. moates.net has a nice chio kit.
Old May 13, 2006 | 02:51 PM
JDM_EK_621's Avatar
no i can pull the chip out.. there is another part under the chip that i soldered in first then pushed the chip into place
i can drive the car untell it heats up and then it dies
i unpulged my Apexi V-AFC 2 controler and then it thro the code 21 VTEC Solenoid (VTS)
so i donno lol
Old May 13, 2006 | 06:51 PM
well if it heats up then dies something must be wrong with the fuel or spark at warmed temp. 160-180.
Old May 13, 2006 | 11:12 PM
JDM_EK_621's Avatar
yea i think it is something to do with the fuel i need to get it retuned but need some software i have a laptop to do it with i just need the data cable and software.
cuz after its warmed up the car will start but then slowly die out with in 5 sec.
Old May 14, 2006 | 04:36 AM
SuperSi's Avatar
I really think you should have done alot of research before you did that. Research is key or lurk around here.
Old May 14, 2006 | 08:59 AM
JSPECSIR's Avatar
Default Re: how do you chip a p28 (SuperSi)
if you cut j1 it will go back to the stock program. i would solder in a 2 pin header with a removable jumper. or a switch with shielded wires.
Old May 14, 2006 | 09:07 AM
JSPECSIR's Avatar
Default Re: how do you chip a p28 (5THGENSI)
oh and your getting that code because your vtec solenoid is no longer connected with the vafc unplugged.
Old May 24, 2006 | 02:24 AM
JDM_EK_621's Avatar
yea well the o2 sensor is fix but i am still in limp mode and lol now i have code 43 come up and i did just replace the fuel filter yesterday
Old May 24, 2006 | 03:30 AM
JSPECSIR's Avatar
Default Re: (JDM_EK_621)
did you cut j1 and try the ecu that way yet.
Old May 24, 2006 | 06:24 AM
JDM_EK_621's Avatar
yea i cut J1 and it did the same thing so i am thinking there is something really wrong with the p28 i bought hummm
hondakook
Feb 17, 2009 07:09 AM
jdmdikk
Aug 22, 2008 07:40 PM
obuhmyuh
15
Jan 5, 2008 01:53 AM
LSR-Abuser
Dec 18, 2007 06:16 PM
krazieV
Oct 17, 2007 10:47 AM
