can electrical vss be interchangeable with mechanical vss?
Old Apr 25, 2006 | 06:31 AM
B18 CYA's Avatar
Default can electrical vss be interchangeable with mechanical vss?
Alright, well my b16 cable tranny that is in my car came with a mechanical vss and I switched out to a hydro gsr transmission which came with an electrical vss that I do not need to wire up nor use since I'm using the stock cluster. Can I just swap the VSS on the tranny from an electrical to a mechanical? Thanks
Old Apr 25, 2006 | 10:36 AM
Lsos's Avatar
Default Re: can electrical vss be interchangeable with mechanical vss? (B18 CYA)
I'm pretty sure you can. My cable B16 tranny came with an electrical VSS and I just popped it out and put in the mechanical one. Everything worked. I imagine it would be no different on a GSR tranny.
B18 CYA
Apr 24, 2006 11:23 PM
jdm_lover
Nov 5, 2004 12:22 AM
JohnCRX
Jul 28, 2004 02:03 AM
wickedEFguy
Dec 16, 2002 03:51 PM
