Syncro Replacement
Old Apr 24, 2006 | 04:50 PM
TealEG!'s Avatar
Default Syncro Replacement
my gsr tranny has a 3rd gear grind and i just wanted to know if i have to replace just the 3rd gear syncro or do i have to replace the gear too. i would like to get the gearspeed carbon coated ones but dont know if i need to get the gearset also. can the gear even get damaged or just the syncro.
also if i end up not doing this for a little while will it hurt anything else in the tranny besides the syncro and maybe the gear.
Modified by GBPDC2 at 9:11 PM 4/24/2006
Old Apr 24, 2006 | 07:36 PM
postman's Avatar
Default Re: Syncro Replacement (GBPDC2)
just the syncro but usually once you tear into you replace more than just that
Old Apr 24, 2006 | 09:08 PM
JDMtype Eg6's Avatar
does anyone know the price ranges for replacing 3rd 4th and 5th synchros, because mine is beginning to grind a little in high rpms.
Old Apr 24, 2006 | 09:47 PM
TealEG!'s Avatar
Default Re: (JDMtype Eg6)
you should check out gearspeed.com for their syncros. they are carbon coated and pretty cheap.
Old Apr 25, 2006 | 12:14 AM
YasRex's Avatar
About $200 bucks will do all the syncros I think.
Old Apr 25, 2006 | 01:45 AM
rainforest's Avatar
Default Re: (YasRex)
check to see if the engadgement teeth on your 3rd gear are rounded off. if they are which more than likly they are replace the gear to. if you dont have time to tear down the tranny then order parts i would just order the gear anyways . most time the gear teeth are as bad as the syncro.
Old Apr 25, 2006 | 06:17 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YasRex &raquo;</TD></TR><TR><TD CLASS="quote">About $200 bucks will do all the syncros I think. </TD></TR></TABLE>
Yep, I think thats how much my 3-4-5 carbon coated syncros were from gear-speed..
Old Apr 27, 2006 | 04:55 AM
StorminMatt's Avatar
Default Re: (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">check to see if the engadgement teeth on your 3rd gear are rounded off. if they are which more than likly they are replace the gear to.</TD></TR></TABLE>
And if the engagement teeth are worn, there is a good chance the slider is, too.
Old Apr 27, 2006 | 07:16 AM
SkRiBLaH's Avatar
Default Re: (StorminMatt)
most importantly when you replace your 3-4 syncros, be sure you replace the 3-4 syncro HUB and collar if it looks fucked up.
Old Apr 27, 2006 | 09:11 AM
TealEG!'s Avatar
Default Re: (SkRiBLaH)
so if i were to get the 3-4 gear sleeve set from gear speed and the carbon coated syncro that would basically replace everything for those two gears.
Old Apr 27, 2006 | 10:05 AM
Cap'N_Kirk2.0's Avatar
I did mine recently. Had third gear grind, change 1-5sync from gearspeed 275. It fixed third but 2nd is still jack from bad sleave and hub do to a broken clutch disk spring that broke(all down shift grind).
tmurphnc1985
Transmission & Drivetrain
Feb 2, 2010 05:40 AM
iBrandon
Aug 23, 2007 12:17 AM
HondaRcB
Nov 24, 2006 11:41 AM
charjacq
Jul 27, 2004 01:13 PM
coolboarder
Sep 14, 2003 09:36 AM
