Suspension problems!!!!
Old Apr 30, 2006 | 11:18 AM
Rickcrx's Avatar
Default Suspension problems!!!!
I finish putting new axles on my eg hatch with a jdm B16 and whenever i take off slowly i hear this clunk noise coming from the driver side suspension.I went over to see if everything was tight and everything was fine.Id put new bolt joints on both side whenever i did the axles too.
Also on the pass side between 20mph and 40mph i feel this vibration then after that it goes away.I took the car to get that wheel balance and is still doing it.
Can someone help me with this.Thanx.
Rick
Old May 1, 2006 | 04:20 PM
postman's Avatar
Default Re: Suspension problems!!!! (Rickcrx)
wheel bearing not seated correctly or axle not seated in wheel bearing correctly
Civichatch2k
Suspension & Brakes
Nov 2, 2006 10:07 AM
stealth_EK4
Suspension & Brakes
Aug 21, 2005 09:35 PM
fe519
May 19, 2003 07:29 PM
