Noob question: How do pistons make compression?
Old Jun 6, 2012 | 06:05 PM
mr_munro's Avatar
Default Noob question: How do pistons make compression?
I understand what compression is, but when people buy 'High compression' piston, what changes the compression? is it the shape of the piston, length, width??
Thanks
Old Jun 6, 2012 | 09:10 PM
civickiller's Avatar
Default Re: Noob question: How do pistons make compression?
see any differences
Old Jun 7, 2012 | 02:48 AM
Martian's Avatar
Compression is the relationship of the top surface of the piston to the head at bottom dead center and top dead center. It is a direct ratio of how much volume is available when the piston has traveled all the way down, and then how much it has been compressed when all the way up. Pistons, rods, crank,bore, head, and head gasket can all effect the overal compression ratio.
Old Jun 7, 2012 | 01:55 PM
mr_munro's Avatar
Yea i know that, just asking about the difference in physical properties of a piston...
Old Jun 7, 2012 | 02:00 PM
mr_munro's Avatar
Originally Posted by civickiller
see any differences
Yea ones is flat the other looks cone topped? Which one makes more compression and why?
My guess would be the flat top one because it can go higher into the head?
Old Jun 7, 2012 | 03:32 PM
its the volume in the cylinder at tdc and when its fully down
Old Jun 7, 2012 | 10:34 PM
mouab18c1's Avatar
You guessed wrong.
JAMSiR
May 26, 2010 08:24 AM
I_know
Dec 21, 2002 07:07 AM
4doorH22
Sep 7, 2001 08:29 AM
4doorH22
Sep 7, 2001 06:01 AM
