Read my spark plug...
Old Jul 14, 2012 | 03:16 PM
Sylvain04's Avatar
Default Read my spark plug...
Honda Civic 2004, 140k miles.
The plugs have 35k miles
I would say, oil consumption. What are your thoughts?
Old Jul 15, 2012 | 09:38 AM
fcm's Avatar
fcm
Old Fart
Default Re: Read my spark plug...
Sure looks like deposits... http://www.ngksparkplugs.com/tech_su...qs/faqread.asp 94
Old Jul 15, 2012 | 12:09 PM
HCivExoo's Avatar
That very white color and deposits is a sign of overheating.
http://www.classictruckshop.com/club...park/plugs.htm
The above link and the previous poster's link say the same things. I don't know your set up but it could be advised to go to a colder spark plug range. The only reason i do not believe it is deposits of fuel additives or bad fuel is that there are no actual large deposits only a white coating on the insulator, and electrodes.
Old Jul 15, 2012 | 01:34 PM
Sylvain04's Avatar
They are stock spark plugs, not sure what part number but I'm 100% sure they are what Honda suggests.
My engine burns oil a little, this might explain the deposit on the spark plugs.
Old Jul 15, 2012 | 08:07 PM
grndslm's Avatar
The color is SUPPOSED to be "milky brown", but as long as it isn't TOO white... then your plug looks to be the exact same as the "normal" plug on that NGK link, above.
Get an *EXTRA* *WHITE* plug checked out.
Old Jul 16, 2012 | 08:32 AM
Gunmetal_B20_Hatch's Avatar
Looks perfectly acceptable to me... Maybe just a LITTLE bit on the lean side, but nothing worth worrying about..
Old Jul 16, 2012 | 12:43 PM
Sylvain04's Avatar
Question....
How can my engine be lean if it is all stock?
Old Jul 16, 2012 | 06:00 PM
aging O2 sensor... CEL? Do you have the ability to look at live OBD2 data?
Old Jul 17, 2012 | 07:58 AM
Sylvain04's Avatar
Yes I have an OBD II reader, no code.
The check engine light has never turned on in 135k miles Good car! LOL
Old Jul 17, 2012 | 08:46 AM
I was more-so referring to "live data" AKA reading parameters while the engine is running.
Either way, I wouldnt worry about it much. If the car runs good and doesnt have any driveability issues and still gets good MPG, just keep on drivin'
Old Jul 17, 2012 | 01:30 PM
Sylvain04's Avatar
Yes, the car runs fine and still get 38mpg on highway and 31mpg city driving.
Just burning a little oil and that's all
Thanks
Old Jul 17, 2012 | 02:30 PM
Phil M's Avatar
It's that way because it runs lean at part throttle. Case closed, next.
Old Jul 17, 2012 | 03:01 PM
Sylvain04's Avatar
Yep and thank you all for your help
Old Jul 17, 2012 | 05:02 PM
JDMxCHICK's Avatar
Icon2 Re: Read my spark plug...
As long as it aint black/chalky you shouldnt have nothing to worry about. o...
ZXiPoZ
May 3, 2012 09:25 AM
NemesisCBR
Jan 22, 2009 08:36 PM
sd_ej1
Dec 15, 2008 07:10 PM
igo4bmx
Apr 6, 2003 08:18 PM
