removing h22a1 head from block
Old Jun 28, 2012 | 02:43 PM
97accordbuildlx's Avatar
Default removing h22a1 head from block
ive removed everything including hoses cams, the support bracket under the intake manifold etc. but i was wondering is there anything on the timing belt side of the engine that i need to take off? does an yhting on the timing belt side hold the h22 head onto the h22 block?
Old Jun 28, 2012 | 04:08 PM
GhostAccord's Avatar
Default Re: removing h22a1 head from block
Aside form the timing belt and the covers, no!
Old Jun 28, 2012 | 04:21 PM
Basik_One's Avatar
Mine had one bolt to the head from a bracket, the bracket is attached to the motor mount bracket going to the block. Did you remove the plastic timing belt covers?
Old Jun 29, 2012 | 10:37 AM
okay thanks i thought so. and na i havent really touched anything on the timing belt side i basically just slipped off the timing belt enough to get the cams out. (and yes the headbolts are removed)and i think i know which bolt you are talking about its about a 12mm towards the top middle area correct?
and do i have to drop the engine on the drivers side? i was going to try and not drop it but idk
im going to have to buy a helms manual for the torque specs and things like this next week..
alx_90ef
Apr 25, 2011 02:12 PM
4doorcivic16
Apr 28, 2010 04:52 AM
accord2civic2prelude
Aug 15, 2009 04:28 AM
project:JDM
Jul 20, 2009 10:14 PM
EFsSuck
Dec 12, 2008 08:06 PM
