Weird misfire/ Jerking No CEL
Old Jun 11, 2012 | 02:34 AM
thegatekeeper14's Avatar
Default Weird misfire/ Jerking No CEL
So my DD mini me has been acting strange lately. I am unsure as to why this is happening i have replaced some parts so see if they would solve the on going issue.
the car mis fires bad at start up but seems like it will rev fine. just have to stay on the gas till is "figures things out" and get back to a somewhat normal running state. the car will jerk and misfire bad if you attempt to drive it, or just dies if you dont give it gas. I also get random jerks and what seems to be like loss of total engine power while driving, i can press the gas as much as i want or let off. the engine will suddenly come back to life and act as if everything was fine again.
I have NO CEL
I have about 6k miles on this setup and am just now having issues.
engine setup:
d15 block z6 head
tuned on e85
DSM 450cc injectors (inline resistors)
I/H/E
chipped p28
parts replaced:
plugs
wires
lignitor
Thanks, this is my DD and need it running swell ASAP!
Old Jun 11, 2012 | 06:35 AM
Default Re: Weird misfire/ Jerking No CEL
NO input? even after that many views?
some advice would be nice.
Thanks
Old Jun 11, 2012 | 04:07 PM
mouab18c1's Avatar
Check your timing.
Old Jun 11, 2012 | 05:22 PM
nothing changed timing wise.
Old Jun 11, 2012 | 05:57 PM
mouab18c1's Avatar
Did you look at it or just guessed in your underpants?
Could possibly be a faulty distributor.
Or did you put in the wrong fuel.
Old Jun 11, 2012 | 06:39 PM
nope fuel is fine.
ichecked the timing, ill start with coil and cap/rotor
Old Jun 16, 2012 | 08:12 PM
hellifiknow's Avatar
Is the problem just at startup or does it occur while driving after the motor gets up to operating temp?
Are your injectors spraying? I would say try check that, compression and spark plugs.
Old Jun 19, 2012 | 05:31 PM
MojicaEric's Avatar
make sure you check spark plug gaps and the your rotor is not loose. i had a smillar problem on my H22a. my screw backed out and the rotor was making the hole in the rotor more of a circle. there could be alot of pidding in the cap also
Old Jun 19, 2012 | 06:22 PM
Gunmetal_B20_Hatch's Avatar
wideband in the car??
have you pulled a plug? know how to read plugs?
mysuperslowej1
14
Sep 9, 2012 06:13 PM
95hondaAccord
Jul 17, 2010 03:07 PM
Civicman86
Apr 18, 2006 07:16 AM
Vtec92Civic
Mar 24, 2005 08:13 PM
