T1R: catalytic converter
Old Jun 9, 2012 | 03:52 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Icon6 T1R: catalytic converter
Does any1 have experience with this product? testpipe
http://www.aj-racing.com/shop/produc...cat=421&page=2
It doesn't include the secondary O2 sensor bung, and wondering what people do with it?
Not sure if other Cat's are similar. But wouldnt it throw codes for not having the O2 sensor hooked up?
Also what are some options for header choice that are compatible with this product?
thanks
Old Jun 9, 2012 | 04:04 PM
grumblemarc's Avatar
The Grumpiest
Default Re: T1R: catalytic converter
It's only difference between it and any other Ebay test pipe is that it's resonated to keep noise down. It says as much in the product description. If your car requires a second O2 you'll need to get a bung welded in somewhere and even then you might still trip a code for catalyst efficiency.
Lookie here.
http://www.ebay.com/itm/CNT-Racing-G...#ht_1414wt_905
I know it's for a Hyundai but...
Old Jun 9, 2012 | 04:15 PM
HT Black OPs
yeah just did a quick search and will have to weld a bung on.
Now do i just plug-play my sensor into that? or should i use this...
http://www.typeoneracing.com/catalog...&cat=71&page=1
Does this product take the place of a bung or just connect to it?
thanks
Old Jun 9, 2012 | 04:22 PM
doood's Avatar
been there done that
that screws into the bung then your o2 sensor screws into it. in my experience, those defoulers are hit or miss.
Old Jun 9, 2012 | 04:37 PM
HT Black OPs
thanks for the quick response's
What about header selection, are these compatible with most ? or is it ITR specific?
Old Jun 9, 2012 | 05:08 PM
doood's Avatar
couldnt tell you. been a long time since i dabbled in b series.
Old Jun 9, 2012 | 08:20 PM
amoebiasis's Avatar
I have one of the T1R converters on my swapped civic. Great quality. Had it for about a year or so and no issues. I do remember when I ordered it I got to choose between the JDM size or USDM size. I think the JDM one is 12" and the USDM 17" (dont quote me on that).
Just make sure you dont over-tighten the bolts. The flange is pretty thin. I bent mine a little when I installed it.
taddaceous
Honda Civic (2001 - 2005)
May 2, 2009 09:57 AM
sickofitall1113
Jun 9, 2005 12:18 PM
b18c_dc2_type_r
Nov 22, 2003 05:09 AM
sydag5
Jan 15, 2002 02:41 AM
