Failed 3rd smog test, need some input.
Old Jul 20, 2004 | 11:46 PM
tangina337's Avatar
Default Failed 3rd smog test, need some input.
Sorry this is a double post from the "other honda.." forum. But I have a 95 civic ex sedan, not modified motor wise. I just need some help with this, I have replaced the pcv, O2, cat, air filter and spark plugs. I failed all 3 test that I have gone through.
Here are my last results:
HC (PPM)
15 mph = max 92 meas 141
25 mph = max 57 meas 125
CO (%)
15 mph = max 0.55 meas 1.31
25 mph = max 0.54 meas 1.45
NO (PPM)
15 mph = max 716 meas 1055
25 mph = max 764 meas 639
The smog tech told me that it may be my ecu that is bad or the wiring to the ecu, I haven't checked the wiring on the ecu. But wouldn't I get a CEL if there is a problem with the ecu?
Old Jul 21, 2004 | 07:22 AM
Crazydave's Avatar
Default Re: Failed 3rd smog test, need some input. (tangina337)
EGR valve?
Old Jul 22, 2004 | 01:14 AM
tangina337's Avatar
Default Re: Failed 3rd smog test, need some input. (Crazydave)
From what I can tell or see, I don't see an EGR valve.
shorto85
Jan 19, 2005 10:27 PM
tangina337
Acura TL, RL & ZDX
Jul 27, 2004 04:42 PM
built562
May 4, 2004 11:47 PM
88LXiProject
Oct 20, 2003 09:56 PM
88LXiProject
Oct 2, 2003 10:40 AM
