ecu ?
Old Jul 18, 2004 | 09:16 PM
CRseXxy's Avatar
Default ecu ?
i have a GSR head on a b16 block, and ive converted the injectors to obd-0 along with the distributor and id pretty much all wired up. i was planning on using a B16a1 computer (PW0 i think, or PR3) someone said i need a GSR ecu due to the 2-step v-tec a GSR head requires. which comp should i use? which one is better?
Old Jul 18, 2004 | 09:20 PM
Sack Master's Avatar
Default Re: ecu ? (CRseXxy)
Just go get a skunk 2 manifold for it. I don't think you are going to find an obd-0 gsr computer. If you are really concerned about the butterflies though you could probably run an rpm activated switch to it. But why waste the money just get a new manifold.
Old Jul 19, 2004 | 03:08 AM
Sliced Beard's Avatar
Default Re: ecu ? (Sack Master)
or to save money all togther...just remove the butterflies and get someone to port it
Old Jul 19, 2004 | 05:21 AM
Fobtions's Avatar
Default Re: ecu ? (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">or to save money all togther...just remove the butterflies and get someone to port it</TD></TR></TABLE>
i would not do this. on a b16a block you will lose what lil bottom end torque you have.
Ern87
Jun 26, 2014 03:15 PM
team 15
Jun 18, 2007 12:22 AM
bulori
Aug 14, 2003 09:33 AM
Quetzolcotl
Jun 17, 2003 05:15 PM
turbotime.
May 1, 2003 12:42 PM
