Double stacking head gaskets
Old Jul 21, 2004 | 02:59 AM
PrecisionH23a's Avatar
Default Double stacking head gaskets
Have any of you guys tried this and what were your results?
Old Jul 21, 2004 | 04:28 AM
Sliced Beard's Avatar
Default Re: Double stacking head gaskets (PrecisionH23a)
doesn't Cometic make o.063" thick head gaskets
I would rather trust a head gasket designed to be that thick over two regular ead gaskets stacked.
not to mention that it would probably be cheaper to purchase the Cometic that it would be for two OEM headgaskets or aftermarket
Old Jul 21, 2004 | 04:33 AM
Default Re: Double stacking head gaskets (dirtyd463)
Yep, I'm opposed to stacking 2... especially with boost.
Just asking before I try contacting cometic again this afternoon. It's always good to have all the area's covered in advance. Thanks daniel.
Old Jul 21, 2004 | 04:41 AM
anytime anthony....I am just trying to prevent you from spending money that could potentially be a waste
Old Jul 21, 2004 | 04:45 AM
It's not my car, hehe.
Old Jul 21, 2004 | 04:48 AM
who's is it? Got someone else to cross over to the turbo world?
I was thinking of going turbo until I came across a JDM ITR swap for cheap....now I sell them, it is great
Old Jul 21, 2004 | 08:02 AM
Nikoli's Avatar
it's mine and id rather pay 1000 for a gasket that will work rather than stack 2 and have it **** up
Old Jul 21, 2004 | 08:35 AM
Default Re: Double stacking head gaskets (Deckedlude)
haha I hear that
gosh golly, Anthony and his corner cutting j/k
Old Jul 21, 2004 | 09:13 AM
Nikoli's Avatar
but i would also rather save a 1000 tooo
Old Jul 21, 2004 | 09:27 AM
the head gasket isn't gona be $1000
more like $160-190 at most
Old Jul 21, 2004 | 09:33 AM
Nikoli's Avatar
yea i know that....i wasnt speaking literally
Old Jul 21, 2004 | 09:35 AM
oh ok just wanted to make shure you knew that
Old Jul 21, 2004 | 03:44 PM
Dancing is Forbidden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">yea i know that....i wasnt speaking literally</TD></TR></TABLE>don't worry about him Nick. He's an idiot
Old Jul 21, 2004 | 04:57 PM
Padawan's Avatar
Darth ModerVader
Toda also offers thicker-than-stock gaskets to lower compression, but if the build is extreme, you'd obviously be better off lowering the compression via pistons.
Old Jul 22, 2004 | 10:32 AM
Nikoli's Avatar
Default Re: Double stacking head gaskets (Padawan)
to make a long story short i hydro locked, warped the head which was already shaved and i allready have je 10:1's and my car has been down for almost 2 months so i just want to get it back on the road unless you know someone that wants to buy them
Old Jul 23, 2004 | 06:32 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">doesn't Cometic make o.063" thick head gaskets
they make em even thicker than taht but get some came gears toget your timing back to normal.
Old Jul 23, 2004 | 08:55 PM
TurboJesse
Guest
Posts: n/a
Default Re: Double stacking head gaskets (b18cls1)
It works, alot of cars up here do it sucessfully, i had it on an old setup. Just drill out the rivits and re rivit the 2 headgaskets together. Make sure to use copper spray and tq the headstuds an extra 5lbs.
Remember Precisionh23 is my Hero!!!
Old Jul 24, 2004 | 12:19 AM
Nikoli's Avatar
cometic doesnt make anyhting for the h23
Old Jul 24, 2004 | 09:14 AM
LudeyKrus's Avatar
Well I remember the only difference in the H22 and H23 head gaskets was the fact that one of them had two open passages that the other one didn't have. It seems to me like it was the H22 that had the two closed passages...........
If you can get ahold of one of each, you'll see what I'm talking about. You may be able to just drill out the holes in an aftermarket headgasket to make it work.
Just a thought...
Old Jul 24, 2004 | 11:11 AM
Nikoli's Avatar
Default Re: (LudeyKrus)
i was thinking about doing that
Old Jul 25, 2004 | 02:05 AM
Nikoli's Avatar
Default Re: (Deckedlude)
anyone else done this?
Old Jul 25, 2004 | 09:48 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Have any of you guys tried this and what were your results?</TD></TR></TABLE>
I'm using a mr.gasket stackable kit on my d-series. No problems at all.
Cho0se
Feb 24, 2020 02:59 PM
Jokerchris
Mar 21, 2015 01:42 PM
Brycen
Jan 1, 2010 02:20 AM
proda9driver
Jan 9, 2008 08:23 PM
Jason703Racing
Feb 22, 2006 06:57 PM
