I've the choice between .....
Old Jul 21, 2004 | 01:01 AM
Special B's Avatar
Default I've the choice between .....
hello, I have a B16A2 (SirII in us i think) and some modifications above, ECU OBDI P30 with chips home made with rev-limit 8800 rpm, Cam CTR, valve spring CTR, intake manifold AEBS, CAI J&R, head port and polish with 11.0cr and more.... my question is:
I've the choice between two throttle body. either are type R 62mm polished, or a JG 65mm. which of the 2 advise me? and which is advantage and of disadvantage of the 2?
thanks
Old Jul 21, 2004 | 04:26 AM
Sliced Beard's Avatar
Default Re: I've the choice between ..... (Fabulous Vtec)
I would honestly go with the 65mm and port match it to the intake manifold
you will have better throttle response and you will have more air available to feed the better flowing cams
karlo123
Jan 1, 2016 08:44 AM
JDMluvDSMkila
Jan 30, 2012 11:36 PM
SpeedImage3
May 21, 2005 08:39 PM
insomniac791
18
Aug 4, 2004 03:36 PM
b16a1civichb
May 6, 2003 07:27 AM
