questions about code 21 on check engine.... no vtec
Old Jul 22, 2004 | 03:03 AM
ViXoN Hatch94's Avatar
Default questions about code 21 on check engine.... no vtec
if i change the complete vtec solenoid, will i have vtec again or will it get rid of the CEL?
thanks
Old Jul 22, 2004 | 04:53 AM
JimBlake's Avatar
Default Re: questions about code 21 on check engine.... no vtec (ViXoN Hatch94)
If that solenoid is bad then it'll be fixed. If your real problem is a loose wire somewhere, then a new solenoid won't fix it.
Old Jul 22, 2004 | 07:26 AM
SpyderZEX's Avatar
Default Re: questions about code 21 on check engine.... no vtec (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If that solenoid is bad then it'll be fixed. If your real problem is a loose wire somewhere, then a new solenoid won't fix it.
This happened to me. Make sure that you check all of your wiring to the solenoid. Make sure that you connections to the ECU are completely plugged in, nice and tight. Also, reset the ECU and check it again. I did this, and come to find out that I just needed to push the connectors in on the ECU. Good Luck.
donnjuan2point2
Sep 15, 2003 10:03 PM
Mentat Ghola
May 15, 2003 10:15 PM
Hondasaurs
May 5, 2003 03:00 PM
prjctCIVIC
Jul 7, 2001 09:50 PM
