Can some one please help me ASAP!!!
Old Jul 18, 2004 | 06:24 PM
killa_lude's Avatar
Default Can some one please help me ASAP!!!
i have a 93 prelude, and i cant get the damn cv joint into the intermediate shaft!!! i cant pull off the hub bolt, because its rusted on. right now im trying to pound it in, with the axle still in the cv joint. i just have to pound it in enough so it will click into the ring. can some one help me!!??
Old Jul 18, 2004 | 08:23 PM
killa_lude's Avatar
Default Re: Can some one please help me ASAP!!! (killa_lude)
bump
Old Jul 18, 2004 | 11:43 PM
killa_lude's Avatar
bump.
Old Jul 19, 2004 | 03:37 AM
Sliced Beard's Avatar
make shure that the ring isn't "floating" out of the grove....if it portrudes on one side more than the other it will act like a stop and keep you from installing it......I hate axles
Old Jul 19, 2004 | 08:36 AM
vtec69's Avatar
try spraying some lube in there so it slides in a little bit better
but first check the ring and if its in there correctly then try a lil lube
-Brian
Old Jul 19, 2004 | 09:07 AM
killa_lude's Avatar
Default Re: Can some one please help me ASAP!!! (vtec69)
yeah the ring is in the groove, but it just wont go in. is there any good way to hit it?
Old Jul 19, 2004 | 09:31 AM
LudeyKrus's Avatar
So it's the big 36mm axle nut that you can't get out?
I don't think you're gonna be able to get enough force to knock it in.
The way I did it was hold the axle straight aligned w/ the IS, then whack it on the end of the axle that goes into the hub. If you hit it hard enough, it will go in!
It seems to me the fact that it's still bolted to the hub will keep you from being able to hit it hard enough to pop in at the IS.
Old Jul 19, 2004 | 10:41 AM
killa_lude's Avatar
Default Re: (LudeyKrus)
hmmm so theres no way...to get it in with the axle bolt bolted up?
Old Jul 19, 2004 | 10:42 AM
LudeyKrus's Avatar
Default Re: (killa_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">hmmm so theres no way...to get it in with the axle bolt bolted up?</TD></TR></TABLE>
I'm not saying that for sure, it's just that it seems unlikely to me.
Old Jul 19, 2004 | 12:29 PM
killa_lude's Avatar
ok well im going to try to get the axle nut off today.
Old Jul 20, 2004 | 04:14 PM
killa_lude's Avatar
i got the axle nut off, and i can hit the axle all the way so its flush with the rotor, but it still didnt snap in. so do i have to take off the rotor and hit it?
Old Jul 20, 2004 | 07:24 PM
murtnabila's Avatar
If the axle if flush with the tranny and sealed you are fine. If you are still having problems put some grease on the axle and set the ring dead center so it's not sticking out too much in one direction. The grease will help keep the ring in place as well as act as a lube. I've had this problem and it's amazing how much the grease will help you!
Old Jul 20, 2004 | 07:39 PM
killa_lude's Avatar
Default Re: (murtnabila)
its not the tranny side, its the driver side axle that goes into the intermediate shaft.....theres alot of grease in the cv joint...is there a way that i can bend the ring in a bit so it wont stick out so much in any one direction?
Old Jul 20, 2004 | 07:51 PM
murtnabila's Avatar
in case your ring is stretched out you can go to a kragen or something an get a new ring and replace your old one.
Old Jul 20, 2004 | 10:31 PM
killa_lude's Avatar
yeah i might end up doing that. ]\
do they have a site?
Old Jul 21, 2004 | 05:54 PM
murtnabila's Avatar
site? kragen is a local auto parts store. Find any that are near you and they should have it. Also try and use a wire brush and going with the grooves and clean it up a bit. There might be some rust or something that is causing a problem maybe (throwing out any bullshit I can!?)
Old Jul 21, 2004 | 07:18 PM
killa_lude's Avatar
ok cool i will let you know how it goes.
Old Jul 23, 2004 | 03:58 AM
tad49's Avatar
Hi, take the ring off & see if the axle will slide in, if it does, then the ring is your problem. while the ring is off, squeeze it together then gently push it back on the axle so it is a tighter fit. Good luck....Tad
Old Jul 23, 2004 | 09:20 AM
killa_lude's Avatar
Default Re: (tad49)
ok thanks man.
neonkid
Oct 12, 2012 01:51 PM
SoOHiGH
18
Jul 6, 2005 07:48 PM
ILLICON3000
Mar 3, 2005 11:13 AM
DIYaccord
Jul 25, 2004 03:19 PM
ill phil
May 15, 2003 06:27 PM
