help cam seal leak
Old Jul 20, 2004 | 10:31 PM
TURBOFTW's Avatar
Default help cam seal leak
ls bottom
gsr head:
Ok on the intake cam seal on the timing belt side i cannot seem to get it to stop leaking i have yet to replace the seal i put it together without any sealent (sp?) and it leaked so i tore it apart again and put some high temp black silicone and it still is leaking also the cam cap that is closest to the cam gear is a little worn nothing major as far as i can tell, all the rest are fine could this cause it? i also noticed that while the motor is running i watch the intake cam gear ( aem) and it doesnt look to be spinning completely true, but the exhuast is spinning perfect.... please and help
Old Jul 21, 2004 | 04:52 AM
Sliced Beard's Avatar
Default Re: help cam seal leak (h22dude)
I would suggest getting a new set of cam seals and a nice tube of Hondabond HT fromt he dealer and your leaks will be gone
Old Jul 21, 2004 | 06:34 AM
TURBOFTW's Avatar
Default Re: help cam seal leak (dirtyd463)
should i replace the cam gear? it looks to be bent?
Old Jul 21, 2004 | 07:06 AM
well if it is bent, definately replace it....it will create harmonics that could potentially harm engine components
and if you do replace it let me get it off of you to add to my little collection of useless parts....(it is a retarded hobby I have)
Old Jul 21, 2004 | 07:48 AM
TURBOFTW's Avatar
lol u pay for shipping and u can have it if it s bent
Old Jul 21, 2004 | 07:54 AM
ok cool....i'll do that
what kind of engine do you have....I might have some cam seals for ya
Old Jul 21, 2004 | 08:31 AM
Gump's Avatar
buy your cam seals at inlinefour if your close, they're only 10 bucks for both, while at the dealer they're 10 bucks each.
Old Jul 21, 2004 | 08:37 AM
Default Re: (Gump)
or you can just got to auto zone or advance auto parts and get them for about 3-5 bux a piece
Old Jul 21, 2004 | 09:28 AM
TURBOFTW's Avatar
Default Re: (dirtyd463)
im in az, quick question the cam cap thats closest (sp?) to the cam gear on the intake side had some wear could this cause my cam to maybe be not spinning perfect and wear out the seal?
Old Jul 21, 2004 | 09:34 AM
Default Re: (h22dude)
if your cam caps are not tight that could result in a bent set of camshafts
you need to make shure everything is in proper torque spec before you start buying things....and yes, if the cam si wobbling it can cause premature wear of the cam seal
Old Jul 21, 2004 | 10:38 AM
TURBOFTW's Avatar
all of the cam caps were torqued to 18ft and the little 10mm were to 8lbs just the one cap has some wear im going to be takeing it off and i ill post a pic...the cam looks perfect
Old Jul 21, 2004 | 01:18 PM
TURBOFTW's Avatar
Heres a pic of the cam cap that has some wear marks....
Old Jul 21, 2004 | 01:32 PM
eh that cap is fine.....just use some hondabond ht on the cam seal that you install
either that or some "mega grey gasket maker for imports" (they sell it at advance auto parts)
Old Jul 21, 2004 | 01:37 PM
TURBOFTW's Avatar
I appreciate your help....thankyou
nutball72
Aug 21, 2006 01:47 PM
TURBOFTW
12
Jul 21, 2004 10:38 AM
TURBOFTW
Jul 20, 2004 10:50 PM
