How do you reset the maintenance lite on 2000 acord?
Old Jul 21, 2004 | 02:23 PM
daddycivic's Avatar
Default PLEASE HELP!!!! How do you reset the maintenance lite on 2000 acord?
I fix and got the engine check lite off. How do I get the maintenance. lite to turn off?
Thanks for the help!
Modified by daddycivic at 9:31 PM 7/21/2004
Old Jul 21, 2004 | 04:13 PM
kidkombo's Avatar
Default Re: How do you reset the maintenance lite on 2000 acord? (daddycivic)
hold that one button ( right side i believe), *with key off* then turn to ignition two..and wait until it stops blinking..then i think you take the key out, and let go of the button...start the car and then see if it goes away after staying on for a bit...
i know its something like that...sorry if i confused you.
Old Jul 21, 2004 | 04:49 PM
7PSI CRX's Avatar
Default Re: How do you reset the maintenance lite on 2000 acord? (kidkombo)
Right.
Push in and hold the tripmeter reset button.
Turn the key to the "ON" position.
Wait untill the Maint light goes off.
Release button, turn off key.
Old Jul 21, 2004 | 08:30 PM
daddycivic's Avatar
Default Re: How do you reset the maintenance lite on 2000 acord? (7PSI CRX)
I try that it didn't work. Anyone know any other way to shut it off. It's a v6 if that make any difference. It doesn't blink just stay on. Please help!
Old Jul 21, 2004 | 08:42 PM
the DR.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">Right.
Release button, turn off key.</TD></TR></TABLE>
exactly as qouted, it may take 10seconds or more, but it will turn off.
Old Jul 22, 2004 | 07:31 AM
SpyderZEX's Avatar
Default Re: How do you reset the maintenance lite on 2000 acord? (the DR.)
Do the accords have a back up fuse that you can pull, like the civic? I don't know that much about accords, but that might be an option. I'm sure somebody, who knows better, can correct me on this.
Old Jul 22, 2004 | 10:23 AM
nevamind's Avatar
Default Re: PLEASE HELP!!!! How do you reset the maintenance lite on 2000 acord? (daddycivic)
I have an Accord too, and I just pull out the bulb behind the gauge cluster that lit the Maint Req ligh. Local dealer charge me $250 to turn off that light
Old Jul 22, 2004 | 06:53 PM
koolb's Avatar
Default Re: PLEASE HELP!!!! How do you reset the maintenance lite on 2000 acord? (HIStateEG6)
identifix says it can take up to 3 min hope that helps.
cam3ron88
Jul 31, 2019 08:05 AM
lmike6453
Jul 18, 2007 04:24 PM
HYPEBEAST!
Honda S2000
Apr 8, 2007 06:07 PM
Corruption
Oct 28, 2005 11:10 AM
lowRIDAH
Aug 10, 2005 06:50 PM
