timing belt tension question
Old Jul 21, 2004 | 06:37 PM
weraider30's Avatar
Default timing belt tension question
how much slack should there be in the belt?
Old Jul 21, 2004 | 08:17 PM
weraider30's Avatar
Default Re: timing belt tension question (weraider30)
no techies out tonight?
Old Jul 21, 2004 | 11:01 PM
STG3PWR's Avatar
not much, should get it pretty tight
Old Jul 22, 2004 | 05:27 AM
weraider30's Avatar
Default Re: timing belt tension question (ADVANcrx)
how do i tighten...i tightened the tensioner all the way and on the longside (front) of the belt it seems to be a little loose
Old Jul 22, 2004 | 06:08 AM
tgreaves's Avatar
You loosen the tensioner and turn the crank in the proper direction 3 cam teeth and then tighten the tensioner..
SpyderZEX's Avatar
If you have a helms manual it should tell you the proper way to tension the belt. I believe that it is 3 cam teeth of a turn, or something like that, of the crank. Then tighten the tensioner.... Good luck
Old Jul 22, 2004 | 08:54 AM
weraider30's Avatar
Default Re: timing belt tension question (SpyderZEX)
i have the chiltons...cool, i will try and let you all know, thanks for the help
Old Jul 22, 2004 | 11:35 AM
skunk2eg's Avatar
the belt will be a little loose untill the car is warmed up.... also the intake side tends to have a bit more slack
Old Jul 23, 2004 | 07:23 PM
weraider30's Avatar
Default Re: timing belt tension question (skunk2eg)
well i won't have the engine in until it is finished, and i wanted to make sure that everything was good to go before i dropped it in...would be a pain to do timing belt work with it in
Old Jul 23, 2004 | 07:29 PM
RedRocketCRX's Avatar
incase they havent told you yet you shouldnt be able to turn the belt more then 90 degrees ones everythings been tighned down.
Old Jul 23, 2004 | 08:05 PM
weraider30's Avatar
Default Re: timing belt tension question (RedRocketCRX)
shouldn't be able to with a wratchet?
Old Jul 24, 2004 | 10:36 AM
with your fingures on the actual belt . between the cam sprocket and the crank pulley(front). if you can rotate the belt more than 90 degrees then its to loose.
kornerk12
Nov 25, 2007 02:03 PM
jvonb
Dec 18, 2005 07:47 AM
1SlowSi
Feb 6, 2005 04:39 PM
RCautoworks
25
Aug 15, 2004 09:17 PM
AdamITR
Aug 28, 2002 07:11 PM
