How to calculate compression ratio
Old Jul 22, 2004 | 07:36 PM
MNsnowdaboy's Avatar
Default How to calculate compression ratio
If I do a compression test on my built motor and got 210 on all cylinder.......how do you calculate your compression ratio?
anyone has a formula or know how much compression my motor have. My JE dish piston is rated at 9.0:1 but with my gasket and welded head chambers I'm not exactly sure where it's at.
Any experts here, I know H-T peeps has the knowlegde.
Old Jul 22, 2004 | 08:38 PM
catolarfo's Avatar
Default Re: How to calculate compression ratio (MNsnowdaboy)
Here you go...
http://www.c-speedracing.com/h...c.php
Old Jul 22, 2004 | 09:02 PM
thanks but that's for oem mixing and matching.
anyone know how much 210 is
Old Jul 22, 2004 | 09:55 PM
boostn420's Avatar
Default Re: (MNsnowdaboy)
a compression test and compression ratio are 2 different things. To figure out exact compression ratio you need to measure a few things while building the motor, combustion chamber volume, and piston dome/dish, and headgasket thickness are a few of the values you need to figure it out.
Old Jul 23, 2004 | 02:15 PM
catolarfo's Avatar
No, that site can be used for much more then OEM mixing and matching. I think you need to do a little more research...compression test and compression ratio are two very different things.
Old Jul 23, 2004 | 04:53 PM
Katman's Avatar
here's another B-series compression calculator for those that are interested...
http://technet.ff-squad.com/cr-calculator.htm
CTR_B
Apr 22, 2008 04:27 PM
Spectrum24x
Jan 15, 2006 05:08 PM
self_made
Jun 19, 2005 12:36 PM
MNsnowdaboy
Jul 22, 2004 08:59 PM
builtprelude
Jan 22, 2004 10:49 PM
