Engine building advice needed
Old Nov 24, 2004 | 05:14 PM
rob42386's Avatar
Default Engine building advice needed
Well im building a Y7/y8 sohc, and i need some advice, me and my friends took my block apart, and saw that the bottom end was really dark smelled bad, (high milage motor) its getting hot tanked and honed so its all good.
I dont knwo what i should replace.
ive got a brand new:
headgasket
timing belt
main, rod, thrust bearings,
z6 rods, and pistons
Things im getting:
Clutch and flywheel
piston rings
all gaskets and misc items
Things im not to sure about??
Oil pump and water pump
I know i should while its out but im pretty much broke!!
Old Nov 24, 2004 | 05:50 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Engine building advice needed (rob42386)
You're definatley going to want to replace the oil pump and water pump.
Old Nov 24, 2004 | 06:14 PM
hondaguyef's Avatar
Default Re: Engine building advice needed (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">You're definatley going to want to replace the oil pump and water pump. </TD></TR></TABLE>
For sure!
Phil
Old Nov 24, 2004 | 09:00 PM
know nothing about your motor but have built many "hi-po" engines, may also want to have the block magna-fluxed, this checks for mircoscopic hole, cracks, as well as the crank, this is cheap insurance. if you have a crak or hole that is not visable you just wasted $$$$$
Old Nov 24, 2004 | 09:07 PM
eda6's Avatar
Default Re: Engine building advice needed ("90acclude")
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "90acclude" &raquo;</TD></TR><TR><TD CLASS="quote">know nothing about your motor but have built many "hi-po" engines, may also want to have the block magna-fluxed, this checks for mircoscopic hole, cracks, as well as the crank, this is cheap insurance. if you have a crak or hole that is not visable you just wasted $$$$$ </TD></TR></TABLE>
good advice
Old Nov 25, 2004 | 07:46 PM
rob42386's Avatar
Ok well i guess ill go ahead and replace it, but ive heard that the Y series have weak oil pumps, should i go ahead and put a z6 pump on and change the pan?
I plan on boosting this motor, and i really dont want to have problems with it.
thanks for the help
Old Nov 26, 2004 | 04:50 PM
rob42386's Avatar
anyone have any suggestions?? y8 or z6 oil pump??
Old Nov 26, 2004 | 07:22 PM
mmuller's Avatar
Mad Scientist
yes older d-series pumps are better, the y8's have lower volume
Eric W
Aug 8, 2011 07:40 AM
mouab18c1
Oct 21, 2008 07:02 AM
boostedb18kid
Nov 10, 2007 02:10 PM
phatrick2332
Feb 6, 2004 09:12 PM
Pfieff
Dec 10, 2003 08:14 PM
