walhbro keeps priming??
Old Nov 28, 2004 | 04:19 PM
b18c1civic95's Avatar
Default walhbro keeps priming??
okay 95 civic hatch. gs-r turbo. put a new pump in(walhbro-255). when i go to turn the key on it started priming but never stopped!! so i figure it's flodding. I start it and it idles up to like 3500. didnt let it run to long to see if it dropped down. the thing is, it keeps doing this. The pump won't turn off. Could this be a result of a bad main relay? i have another ecu i will try. and post what happens. Oh the ecu is throwin a TDC code (8). This happens if i leave it on for about 2 or 3 times the normal length it would take to prime. Earlier my batter was dead and i tried to start it and it clicked off and on several times because i have a starter kill and i thought my foot wasn't pressing it down all the way but it was. usually when its that dead it will just not click or anything. maybe this screwed the relay? i had it started after that so i doubt it but any help would be appreciated.
Old Nov 28, 2004 | 07:22 PM
Default Re: walhbro keeps priming?? (b18c1civic95)
okay i tried a different relay and no luck still the same thing!! it couldn't be that the wires are reversed could it? It's made for the car and doesnt require splicing the wires. or has someone had to do this?
Old Nov 28, 2004 | 07:40 PM
Kamin's Avatar
um the pump can run for as long as it wants, fuel will not enter the engine becuase the injectors are closed.
Old Nov 29, 2004 | 07:56 PM
Default Re: walhbro keeps priming?? (Kamin)
yeah but the pump should only run for 3 seconds to prime. Mine would keep going but it turns out it was a bad Ecu. So i made my dyno appointment on time!!!! I'm so happy lol
turbodx95
Dec 13, 2007 07:12 AM
sup22
Nov 3, 2007 01:22 PM
slow hatch
Apr 19, 2004 10:00 AM
lonefuzzy79
Dec 16, 2003 12:37 PM
