people w/ RC injector knowledge Please help.
Old Nov 23, 2004 | 09:58 PM
dcvt16's Avatar
Default people w/ RC injector knowledge Please help.
i have a set of 270 RC injectors with clips that are obd0, the car they came out of originall was a crx, but unknown if he were running obd 0 or 1.
these ijectors have been used for a while in a obd1 EG, but runs really rich.
my question is... is it possible that these are peak and hold and require the use of a resistor box, and have beed running rich with out one? is that even possible? what make it strange is the engine is a type R, fastest run being 14.1 on street tires an 32 psi FP and the plugs on the injectors are obd 0. any info or thoughts would be great.
Old Nov 23, 2004 | 11:09 PM
dcvt16's Avatar
Default Re: people w/ RC injector knowledge Please help. (dcvt16)
up/\
Old Nov 24, 2004 | 06:18 AM
Used2beAb16's Avatar
I would guess that that crx had a resistor box
Old Nov 24, 2004 | 10:14 AM
Jim Truett's Avatar
Default Re: people w/ RC injector knowledge Please help. (Used2beAb16)
Did you remap the ECU for the 270cc injectors?
Old Nov 24, 2004 | 03:28 PM
dcvt16's Avatar
Default Re: people w/ RC injector knowledge Please help. (Jim Truett)
were using the same mapped p28 that was used w/ the motor and these injectors, the guy was using a obd 0 distributor w/ the p28. so in not sure what was going on before we got ahold of this stuff.
Old Nov 24, 2004 | 03:53 PM
dcvt16's Avatar
i just talked to RC and the injectors are definatly peak and hold , now my question is can the ecu be modified to run these injectors w/ out the use of a resistor box.?
Old Nov 24, 2004 | 04:42 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcvt16 &raquo;</TD></TR><TR><TD CLASS="quote">i just talked to RC and the injectors are definatly peak and hold , now my question is can the ecu be modified to run these injectors w/ out the use of a resistor box.?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcvt16 &raquo;</TD></TR><TR><TD CLASS="quote">the guy was using a obd 0 distributor w/ the p28. </TD></TR></TABLE>
Not possible unless he modified the OBD-0 dizzy to accept the 24 tooth OBD-1 reluctor wheel.
Old Nov 29, 2004 | 10:05 PM
dcvt16's Avatar
well im not sure the deal was before, but i wired in the box and its not right so i jumped the box and it runs fine.. i still not sure why the part is scribed as peak and hold but the dont work that way. oh well it runs good without it so i geuss its ok.
GT500FTW
Nov 29, 2012 03:10 PM
aaronhume
Oct 25, 2005 11:52 PM
UncleBen'sRacing
May 20, 2003 03:17 AM
cccya
Mar 13, 2003 01:38 PM
T60-1VTECrex
Mar 3, 2003 04:52 PM
