some transmissions q&a
Old Nov 22, 2004 | 07:48 PM
CaptinMcnut's Avatar
Default some transmissions q&a
i currently have a 94 d16z6 tranny and a d15b7 tranny both hydro and the d15 has lsds.
so im goin to take out the lsd and put it in my z6 tranny
but the b7 uses like a 62mm washer or something like that and the z6 uses a 70 i think not tottaly sure
when changing this should i use the spacer for the diff for the b7 or the z6 anhy help is appericated thanks
Old Nov 22, 2004 | 08:49 PM
Jim Truett's Avatar
Default Re: some transmissions q&a (Darren90teg)
If it is a true DX/LX D15b7 trans, the diff uses 70mm OD carrier bearings, where the Z6 trans uses 80mm carrier bearings. The bearing OD is 40mm on the Z6 and 30 or 35mm on the B7. The diffs will not directly interchange.
http://home.cinci.rr.com/mistab0ne/tranny.html
Old Nov 22, 2004 | 11:10 PM
Sliced Beard's Avatar
Default Re: some transmissions q&a (Jim Truett)
you will need to get machine work done to the LSD to make it fit properly
Old Nov 23, 2004 | 01:19 PM
Default Re: some transmissions q&a (DirtySol)
ok well what are the ratios's for both trannies? and it's from a jdm d15b7 and a 94 d16z6???
enigma's95
Jun 16, 2008 07:00 PM
SEATownboi08
Feb 20, 2008 07:09 PM
Eli'sEG94
Sep 19, 2007 01:42 PM
bowdown201
Sep 18, 2007 10:32 AM
SIcoup
14
Dec 8, 2003 12:37 PM
