Torque on the crank pulley bolt!
Old Nov 28, 2004 | 08:38 AM
B_Something's Avatar
Default Torque on the crank pulley bolt!
How do you torque the bolt and prevent the pulley from turning? I really need any quick help you guys have.
Old Nov 28, 2004 | 09:31 AM
v4lu3s's Avatar
RTFM
use the crank pulley holder tool or an impact gun
Old Nov 28, 2004 | 11:11 AM
blackeg's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">use the crank pulley holder tool or an impact gun</TD></TR></TABLE>
impact gun is amazing for stuff like this. it will tighten the bolt right up. if you cant get either of the previously mentioned things, then you could always gangster it and stick a big *** screwdriver in the flywheel teeth and wedge it between the teeth and the tranny casing. its not recommended, but it might work.
on second thought, just use and impact gun
Old Nov 28, 2004 | 04:42 PM
JBBNJ609's Avatar
Default Re: (blackeg)
i have had to do the screwdriver in the flywheel bolts thing, it works fine, and i had an impact gun it was still kinda needed
Old Nov 28, 2004 | 05:08 PM
JBBNJ609's Avatar
Default Re: (jerseykid609)
you love threads that i post in . . .
Old Nov 28, 2004 | 07:56 PM
Dan GSR's Avatar
use the crank pulley tool
only way to properly torque it down, without any chance of damagin anything
accord2civic2prelude
Nov 1, 2009 04:22 PM
PreludePhill
Sep 9, 2007 11:06 PM
Baron55
Mar 2, 2007 11:00 AM
BoostedED9
Jun 16, 2002 06:45 AM
