Rotating wheel weight
Old Nov 23, 2004 | 04:18 PM
typhoon's Avatar
Default Rotating wheel weight
I've got a 4th gen accord that I bought and it came with a set of 14" OEM Mitsubishi rims (looks like from a mid '90's eclipse or lancer) it's got some inexpensive Yokos on them.
I don't know if I should be more concerned with the tire weight or the wheel weight. I would think 14' alloys would be pretty light. don't know about the tires.
I don't want to buy a new wheel/tire package if I don't have to.
Does this sound like light rotating mass to y'all?
Old Nov 23, 2004 | 05:10 PM
BeavisB16's Avatar
Default Re: Rotating wheel weight (typhoon)
14" steels are probably around 17 lbs.
Old Nov 23, 2004 | 05:19 PM
purge's Avatar
if you're concerned with weight from a component viewpoint then you have two separate considerations. if it's unsprung weight you're looking to reduce then its the total of the combination not just one of the two. if its weight reduction for the purpose of acceleration then it's more complicated. the angular acceleration of the wheel is follows this formula..
a=T/(mR^2)
where a=angular accel,T= torque, m=mass, R=radius
if you have the values to plug in, have fun!
i suggest you stick to metric values, kilo, meter, sec.
Old Nov 23, 2004 | 05:31 PM
typhoon's Avatar
Not 14" steelies. 14" 6 spoke alloys - cast
notstock93's Avatar
Default Re: Rotating wheel weight (purge)
Simple answer. Tire weight
The farther away from the pivot point (in this case the center of the wheel) the greater the effects of rotational weights.
Old Nov 23, 2004 | 05:37 PM
typhoon's Avatar
Well these are Yoko AEGIS LS4. Anywhere I can find the weight on these? Links?
Old Nov 23, 2004 | 05:40 PM
notstock93's Avatar
no idea. The manufacturer would be able to list the weights, or go to a Vet and use their digital scale (what I do)
Old Nov 23, 2004 | 07:01 PM
Denny Crane's Avatar
Default Re: Rotating wheel weight (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">...go to a Vet and use their digital scale (what I do)</TD></TR></TABLE>
Omg, that's hilarious. What a great idea!
Old Nov 24, 2004 | 11:38 AM
notstock93's Avatar
Default Re: Rotating wheel weight (hybrid2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2nr &raquo;</TD></TR><TR><TD CLASS="quote">
Omg, that's hilarious. What a great idea! </TD></TR></TABLE>
That's how I weighed the original pulleys on my car against the new ones, and the flywheels too. Just gotta ask nicely.
y2kferari
May 8, 2006 03:27 PM
angelovargas
Nov 2, 2003 06:40 PM
shawnhayes
Sep 29, 2002 09:13 PM
Type-Rare#1248
May 15, 2002 12:39 PM
