Oil leak!
Old Nov 28, 2004 | 08:27 PM
hybrid_vtec's Avatar
Default Oil leak!
I have a B18b I just rebuilt a few monthes ago and I am having an oil leak problem from the oilpan around the gasket! At first I removed the oil pan to find metal washers from the last oilpan gasket!(How I missed that is beyond me) So I replaced the gasket and torqued it to 8.5 ft-lbs and now it leaks from another spot on the oil pan and not where it was before and the gasket squeezes out of some places and not others(I am using a torque wrench)! I already bought another gasket and I am going to replace it again, but I just wondered if anyone knows what is causing this!
My engine has P30 Pistons in it and Crower 404's which ups the cranking pressure to 220.84 PSI from 182.68 PSI(which was stock)! I also upgraded my oil pump to a GSR and I wonder if one of these factors may be causing this!
-I have been using valvoline 10W-30 conventional oil!
-I have used new gaskets and haven't used any gasket sealer!
-I have torqued the nuts and bolts to factory spec, 104 in-lbs. or 8.5 ft-lbs.
I have no clue what is causing this to continuously leak! Any input is appreciated!
Old Nov 28, 2004 | 08:30 PM
Kamin's Avatar
Default Re: Oil leak! (hybrid_vtec)
are you using RTV around the corners of the pan gasket? also torquing in order?
Old Nov 28, 2004 | 08:34 PM
Default Re: Oil leak! (Kamin)
Yes I used RTV at the corners where the oil pump meets the block and same on the flywheel side! Yes I have torqued in order, from the center out!
Old Nov 29, 2004 | 06:51 AM
drdisco69's Avatar
You don't just use it in the corners, you use it all the way around. This is how I do them, and I've never seen one leak. Apply hondabond all around the rim of the pan, spread it thin with your finger. Lay down the gasket and make sure it's flat. Then apply another thin layer on top of the gasket. Let that sit for 5 minutes, and install. The layers should be just think enough to cover whatever you're putting it on, no more. And I use a circular pattern to torque, going around on opposite sides. Hope this helps.
Old Nov 29, 2004 | 10:12 AM
Default Re: Oil leak! (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">You don't just use it in the corners, you use it all the way around. This is how I do them, and I've never seen one leak. Apply hondabond all around the rim of the pan, spread it thin with your finger. Lay down the gasket and make sure it's flat. Then apply another thin layer on top of the gasket. Let that sit for 5 minutes, and install. The layers should be just think enough to cover whatever you're putting it on, no more. And I use a circular pattern to torque, going around on opposite sides. Hope this helps.</TD></TR></TABLE>
Thanx, but I thought you were not supposed to use gasket sealer or hondabond all the way around the gasket?
Old Nov 29, 2004 | 11:36 AM
drdisco69's Avatar
Thats how I learned it, and thats what everyone at the dealers I've worked at have done. It's never failed me.
Old Nov 30, 2004 | 10:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Thats how I learned it, and thats what everyone at the dealers I've worked at have done. It's never failed me.</TD></TR></TABLE>
Thanx!
Old Nov 30, 2004 | 02:25 PM
racinategra's Avatar
hmm. i must try this too. oil leaks slow but steady
Old Dec 12, 2004 | 11:50 AM
Default Re: (racinategra)
well Im changing my oil pan gasket now and the gasket is completely soked with oil! I know oil penetrates metal so should I wait a couple of days before reinstalling the oil pan or can I just clean it and reinstall it. What can I clean it with? Should I silicon or hondabond?
Old Dec 12, 2004 | 12:02 PM
drdisco69's Avatar
Default Re: (hybrid_vtec)
Clean it with a carb or brake cleaner, and blow it dry. I use hondabond cuz it's free to me, but an rtv sealant will probably work as well.
Old Dec 12, 2004 | 08:58 PM
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Clean it with a carb or brake cleaner, and blow it dry. I use hondabond cuz it's free to me, but an rtv sealant will probably work as well.</TD></TR></TABLE>
the silicon or the gray gasket maker for imports(supposed to be like hondabond)?
Old Dec 13, 2004 | 07:22 AM
GDM Z28's Avatar
use hondabond.....its the **** lol
Old Dec 25, 2004 | 05:09 PM
Default Re: (civicflnum1)
My oil pan is bent and I need a new one. Does anyone here have a B-series oil pan that they can sell me? Pm me please.
Old Dec 27, 2004 | 07:58 AM
99lsvtecauto's Avatar
pm sent
Old Dec 27, 2004 | 12:31 PM
Default Re: (99lsvtecauto)
Thanx but I already have one
My_EFsedan
Apr 2, 2009 11:43 AM
KillerBee18
Jun 22, 2006 11:21 AM
IntegraB18A
Dec 20, 2003 08:18 PM
NateTEG95
May 29, 2003 08:05 PM
MeanGreenEG9
Dec 18, 2002 07:43 PM
