Need real advice! PRO ONLY
Old Nov 23, 2004 | 11:39 AM
delsolxxxgsr's Avatar
Default Need real advice! PRO ONLY
really need to know if gears from a gsr will fit a crv trans? at least 1st 2nd and 3rd! preferably 4th too.
Old Nov 23, 2004 | 12:12 PM
Denny Crane's Avatar
Default Re: Need real advice! PRO ONLY (delsolxxxgsr)
The trannies I've seen (D, etc.) have the first, second, and reverse drive drive gears integral (no pun intended) with the input shaft. I've also noticed that, again - among the trannies I've seen, that CRX HF, DX, and Si input shafts are all the same.
This means that the only way to "change" 1st and 2nd overall would be to change out the FDR, which means changing out the output shaft....which also means it has to be compatible with the input shaft.
It's not a tranny design like a lot of the Porsches where you can change each individual drive/driven gear pair to get whatever combination of ratios you want.
Old Nov 23, 2004 | 01:02 PM
Default Re: Need real advice! PRO ONLY (hybrid2nr)
not sure i understood it all! the best would be to have all my gsr gears on the crv tranny... but would the driveshaft still work to the rear diff? it's just too long of gears for turbo and way too weak for vtec.... waiting for reply.
Old Nov 23, 2004 | 01:08 PM
I haven't seen it so I'm not familiar with the CRV tranny. Sorry.
Old Nov 23, 2004 | 05:57 PM
ttt still need info!
Old Nov 23, 2004 | 11:56 PM
still looking.....
Old Nov 24, 2004 | 11:03 AM
got no idea???
hondarescue
Transmission & Drivetrain
Apr 8, 2017 02:26 PM
crxdx89
Aug 25, 2004 05:15 PM
rtiadnoh
Apr 4, 2004 08:04 AM
jdmhondageek
22
May 3, 2003 07:34 PM
ED8DX
Feb 28, 2002 09:47 AM
