HELP!! ABS light on.
Old Nov 27, 2004 | 04:53 PM
TypeR0186's Avatar
Default HELP!! ABS light on.
I don't know why my abs light is on. What can i check to see if everyting is ok? i unplug the abs pump recently and plug it back up (just the plugs). it's all plug in now. i also took out the front brake rotor before it happen. Any idea how to fix this problem.. thanks...
Old Nov 27, 2004 | 05:26 PM
drdisco69's Avatar
Default Re: HELP!! ABS light on. (TypeR0186)
What type of car?
Old Nov 27, 2004 | 06:42 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0186 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why my abs light is on. </TD></TR></TABLE>
What trouble code does it have stored?
Old Nov 27, 2004 | 06:48 PM
TypeR0186's Avatar
Default Re: HELP!! ABS light on. (drdisco69)
i have a 01 type r with a k20a swap in it. i cant read any code yet because the link connector is not hooked up yet. just did the axle, can that affect anything?
Old Nov 27, 2004 | 06:51 PM
drdisco69's Avatar
If you have the wrong axle, the sensor wheel may be incorrect, or plain missing. Did it have the sensor teeth on it?
Once you get the DLC hooked up, things will be a lot easier.
Old Nov 27, 2004 | 09:01 PM
rtype11's Avatar
sounds like you used non abs axles, they have a pickup for the abs sensor on them, abs senses only three wheels turning
Old Nov 27, 2004 | 10:02 PM
TypeR0186's Avatar
Default Re: HELP!! ABS light on. (rtype11)
the axle does have the teeth on them, they look very similar to the jdm one. i got these axles from hasport. i know i need to hook up the DLC asap but the problem is... i don't know how too..
siblue_gzer
Suspension & Brakes
10
Aug 13, 2007 04:49 PM
siblue_gzer
Aug 13, 2007 12:17 PM
H22a T13
Nov 29, 2005 09:44 AM
Rain_man
Aug 28, 2001 04:32 AM
