I Need Help ASAP
Old Nov 22, 2004 | 08:25 PM
DSMDude's Avatar
Default I Need Help ASAP
hey i have a 1990 honda accord and all of a sudden i cant get power to the fuel, ignition, and computer but everything else works it will even turnover... any help is greatly appreciated...
ryan
Old Nov 22, 2004 | 09:43 PM
93lsd's Avatar
Default Re: I Need Help ASAP (DSMDude)
check your main relay. that may be your problem
Old Nov 22, 2004 | 11:03 PM
Sliced Beard's Avatar
Default Re: I Need Help ASAP (93lsd)
main relay is most likely your problem
that is a notorious Honda problem
Old Nov 22, 2004 | 11:14 PM
BadWay's Avatar
check the fuses
Old Nov 23, 2004 | 04:14 AM
PrettyLude's Avatar
check the grounds also
Old Nov 23, 2004 | 02:58 PM
DSMDude's Avatar
Default Re: (PrettyLude)
its not fuses
its not ground
and honda told me it was a relay but i just wanted to double check with people who know what their talking about lol it like 55 bux right??
ryan
Old Nov 23, 2004 | 04:22 PM
RedlinedVTEC's Avatar
Default Re: (DSMDude)
yeah $55 sounds right for a main relay.
Old Nov 24, 2004 | 04:00 AM
DSMDude's Avatar
Default Re: (RedlinedVTEC)
bought new main relay still nothing, car ran before new motor was installed,not getting any codes from ecu when i use jumper wire to read dash light, not the fuses or grounds
Old Nov 24, 2004 | 04:03 AM
is you injector jumper hooked up....
Old Nov 24, 2004 | 04:24 AM
DSMDude's Avatar
Default Re: (DirtySol)
injector jumper explain
LS Turbo300
Oct 30, 2021 05:56 PM
CeeRichh
Nov 20, 2014 05:58 PM
F20B6THGEN
Jul 24, 2012 09:20 AM
antiricer
Jan 17, 2007 02:49 PM
WolfGod
Jul 6, 2006 07:58 PM
