whining noise from timing belt area!
first of all i had my timing belt changed around 7k miles ago at Acura. So it has been doing it on and off but now it makes the constant noise. there is a whining noise coming from what seems to be the timing belt that is constant with engine speed. in nuetral it doesnt do it but once i step on the gas it gets louder. its hard to explain but my car sounds like a toy car. also is sounds to be maybe a lose bearing becuase i hear something knocking around. my friend mentioned something about fluid? any help will be appreciated, thanks!
Re: whining noise from timing belt area! (94gsr_vtc)
could be ur waterpump. Check ur coolant level to see if its going down. If it is, then its prolly ur waterpump. I had the same problem...disappearing coolant, then came the whining noise ur talking about....turned out to be my waterpump.
barryfaetheus
07-23-2011 09:47 PM
ekx4
08-28-2006 12:18 AM
bam181
08-20-2006 05:16 AM
