gears stuck
Old Nov 29, 2004 | 09:21 AM
integ R a's Avatar
Default gears stuck
Lately, sometimes when I start in first, my car feels like it is about to stall no matter how much gas I give it. The other night, I was leaving my friends house and when I came up to a stop sign, I couldn't put it in to gear, I went through every gear and it wouldn't budge. Finally about five min. later, it loosened up. I didn't drive it more than a few miles or a couple of days. Today, however, it started to tighten up again and was harder to put in gear. What do you think is the problem. (FYI, I checked my tranny fluid and there seems to be enough, and it pretty clean) Thanks for any input.
Old Nov 29, 2004 | 10:01 AM
snatch's Avatar
Default Re: gears stuck (integ R a)
Linkage (although I wouldn't know why it would get easier then harder), maybe clutch/clutch fluid?
Old Nov 29, 2004 | 03:54 PM
integ R a's Avatar
thanks for the help, anyone else have any input, i appriciate it.
Old Nov 29, 2004 | 03:56 PM
drdisco69's Avatar
Dragging clutch perhaps? Dunno about the changing though. Bent or broken pressure plate springs?
Old Nov 29, 2004 | 04:02 PM
msmotorsports's Avatar
Pull the tranny and check the clutch out. I bet the springs are damaged.
africanqueen's Avatar
Default Re: gears stuck (drdisco69)
check the clutch cable. It could be too tight or to loose. Just something to check.
Old Nov 29, 2004 | 04:12 PM
integ R a's Avatar
Default Re: gears stuck (africanqueen)
that actually happened with the cable about two months or so ago, so it was replaced. So I don't think that would be it, also, the tension in the clutch seems to be, for the most part, fairly normal most of the time. Thanks for the suggestion though.
Old Nov 29, 2004 | 05:40 PM
86si's Avatar
clutch is hangin proly due to a broken spring
Old Nov 29, 2004 | 07:43 PM
integ R a's Avatar
Default Re: gears stuck (86si)
anyone else have any input?
Old Dec 1, 2004 | 09:40 AM
integ R a's Avatar
bump
Old Dec 1, 2004 | 09:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
If its a hydro trans, check your slave and your fluid level. I know when a slave is starting to go bad, it will catch really low or not engage or disengage at all, until you pump it up.
Old Dec 1, 2004 | 10:57 AM
Dan GSR's Avatar
Default Re: gears stuck (JDM_Ej)
does it go thru the gears fine with the car off?
if so, then your clutch is done
Old Dec 1, 2004 | 12:17 PM
sammysnakes's Avatar
Default Re: gears stuck (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Pull the tranny and check the clutch out. I bet the springs are damaged.</TD></TR></TABLE>
Old Dec 2, 2004 | 08:06 PM
integ R a's Avatar
Default Re: gears stuck (chainsaw)
bump
Old Dec 2, 2004 | 08:21 PM
Dan GSR's Avatar
why bump it, if you didn't answer my question?
answering the question will help me, to help you
Old Dec 5, 2004 | 05:52 PM
integ R a's Avatar
Default Re: gears stuck (Dan GSR)
my bad, i must not have been paying attention. When it got stuck, I didn't turn it off to check, i just worked it until it loosened up, so I am not sure.
Alchemist Dragon
Classic Hondas
Jul 18, 2010 04:00 PM
DANINE101
Transmission & Drivetrain
Mar 13, 2010 10:04 AM
02_Si_FTW
Jul 21, 2008 01:57 AM
tenjintuned
Apr 8, 2006 04:18 AM
spidermancivic
19
Jun 24, 2005 10:30 PM
