Oil dipstick length issues
Old Mar 19, 2021 | 02:55 AM
Diandre Pree's Avatar
Default Oil dipstick length issues
Hello, I am having an issue I can't seem to resolve. I had a obd1 d15b8 that was having issues. Had it swapped for a obd2 jdm d15b non vtec. All the obd1 parts were swapped over from the old engine to the jdm d15b. The d15b did NOT have a dipstick for some reason so I used the one from the usdm d15b8 I had in the car. Upon filling the car with 3.5 quartz of oil the usdm dipstick seems to be too short as it comes out dry and reads that the engine has no oil. I tryed to get a obd2 1.6 nonvtec dipstick from autozone hoping that was the usdm equivalent but they gave me a dorman dipstick that was like a foot too long. Any help will be great thanks!
Old Mar 19, 2021 | 07:18 PM
Ryanthegreat1's Avatar
Default Re: Oil dipstick length issues
3.5 quarts seems low. Add another half quart and see if it reads on the stick.
Are the dipstick tubes the same length on the blocks? Oil level will be more set by crankshaft height. If the dipstick tubes are the same then the distance from the oil level to the crankshaft will be the same. JDM oil pan might be a larger capacity.
Old Mar 20, 2021 | 02:41 PM
​​​​​​Hey thanks for your response. I previously tried to fill the engine until the dipstick had oil on it and I ended up using 5 qts and upon driving the car began smoking really badly. I drained the oil and refilled to the recommended amount of 3.5 qt. The main difference is on the usdm engine the dipstick was center, but on the jdm engine it's offset to the right near the belts. I'm not sure if it goes into the oil pump directly but it's hard to find any info. I no longer have the old engine so I can't look at the oil tube but I will see if I can find a picture to compare with.
Old Mar 20, 2021 | 03:28 PM
You want a Y8 dip stick. Those were off on the end near the belts.
crookson speed
Sep 15, 2013 12:30 PM
return_2020
Honda Civic (2001 - 2005)
Sep 2, 2006 06:44 PM
onceabunny
Aug 7, 2006 11:51 PM
EK45VTi
29
Apr 30, 2004 07:37 AM
