Question: Is it possible to bypass the VTEC oil pressure sensor?
Old Apr 10, 2020 | 04:29 AM
Raipe's Avatar
Default Question: Is it possible to bypass the VTEC oil pressure sensor?
Hi! I broke couple days ago my vtec oil pressure sensor and i have an issue now. My S2k wont rev past 6.5k. Is there a chance to bypass the vtec oli pressure sensor in F20C? I hooked up one wire from the sensor and it works for a while, but under hard acceleration it suddenly stops reving over 6.5k. Restarting the car after hard accelerarion it works again for a while, until you rev it past 6.5k for a good period. How is the correct bypass wiring done? And does somebody know what is the resistance of the sensor if i put an resistor into the wiring which goes to the ecu? I can post an picture below how the setup is now done😁
Raipe
Honda S2000
Apr 10, 2020 04:35 AM
jdubEP3
Jan 26, 2012 05:23 AM
PinkMaggit
Mar 12, 2007 05:43 AM
tegsallgood
Jan 8, 2005 06:19 PM
