Tps trouble
Old Feb 25, 2021 | 07:12 PM
Kotaray's Avatar
Default Tps trouble
Tps has 12v supply! I just swapped a 97 h22 into my 2000 ej8 y8 obd2b. I cant figure out what is going on. I've deloomed the engine harness and cant find any exposed or pinched wires. I dont have the map and tps mixed up either. Please help!
Old Mar 5, 2021 | 06:10 PM
Accordian47's Avatar
10 Year Member
Default Re: Tps trouble
Could be a problem with the ecu sending 12V out a driver that is supposed to be 5V. Have you checked the supply voltage @ other sensors to confirm they are the 5V they are supposed to be?
Old Mar 5, 2021 | 06:17 PM
Kotaray's Avatar
so I found out that my ecu ground to the thermostat housing needed a good sanding. So once I did that I got a correct reading.
j.bro
Honda Civic (2001 - 2005)
Nov 22, 2011 04:55 PM
cranker
Jul 15, 2010 03:22 PM
jfruauff
10
May 3, 2008 11:41 PM
nickcrx
Oct 6, 2005 04:33 PM
wade
May 31, 2004 12:32 AM
