What throttle cable to use
Old May 15, 2020 | 11:52 AM
Bro-die's Avatar
Default What throttle cable to use
I'm doing an lsvtec swap on my ek. Its been over a decade since I've done my other ek and I'm lost. I remember when I did the swap I had to use a different throttle cable. I'm using a gsr head with skunk 2 intake manifold and skunk2 throttle body. With the skunk2 throttlw body what throttle cable and bracket should I use. Ive been reading to use si or type r. So which is the riggt one? Please help!! I'm pretty sure there are hundreds of you guys that did this swap before. Thanks in advance.
Old May 15, 2020 | 10:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: What throttle cable to use
The ITR cable and bracket are going to fit the closest... you will have limited adjustment range in an EK. You may have to bend the bracket a bit to get it right.
autoxthis
Aug 9, 2008 07:48 PM
e she i
Feb 7, 2007 08:15 AM
krucial7integra
Jan 11, 2007 12:31 PM
SpoonEk253
May 20, 2006 11:42 AM
