2nd fan not turning on
Old Aug 21, 2020 | 10:05 PM
jdmericteg's Avatar
Default 2nd fan not turning on
Hi honda tech. I just got my car back from the shop from gettin k swapped. I bought 2 fans for the radiator but only 1 turns on. The shop said the 2nd fan runs with the ac. But i have the ac and power steering deleted. My question, is there a way to have both fans run? Just hoping i didnt buy an extra fan that i dont need and is useless without ac. Any input/advice would be greatly helpful and appreciated. Thanks!
Old Aug 22, 2020 | 05:25 PM
jdblock's Avatar
Default Re: 2nd fan not turning on
use a relay, trigger it with the stock fan wiring.
Old Aug 23, 2020 | 12:18 PM
Ryanthegreat1's Avatar
What chassis?
Old Aug 23, 2020 | 12:52 PM
ERA_Evil's Avatar
What car? And in any case, 2nd fan is pointless on older civics, since the rad and condenser are side by side and separate.
if it is a full size rad/condenser where one is in front of the other then turning on the 2nd fan is a good idea, in which case you could tie in the second one with the first.
You can splice it in, but in honesty I would recommend getting the second fan to turn on with the first but with a relay so as to not burden the electrical wiring of the first.
Old Sep 1, 2020 | 08:21 PM
jdmericteg's Avatar
Thank you for the replies! Chasis is a 96 integra. I have a full size oem rsx radiator with 2 mishimoto fans. I dont know much when it comes to electrical so i will be asking the shop to take care of wiring it to the first with a relay. Thanks again!
Noob@Cars
Mar 1, 2016 05:53 PM
VIS250P
Jan 4, 2007 02:01 PM
kholmes
May 11, 2005 08:39 PM
jazz215
Aug 23, 2003 10:48 PM
