HELP!!!! ls/vtec swap
Old Mar 12, 2009 | 06:36 AM
thefesone's Avatar
Default HELP!!!! ls/vtec swap
Yo what up?! So i been workin on my lsv swap into my 96 teg. got the motor in all is good there but it wont start! Im using a b18a block with a 98 type r head, the stock obd2 engine harness, an obd2 to obd1 jumper harness in the cabin so i can use my p28. When i use the p28 i get power to my injectors but no spark, but when i change back to obd2 i get no power to my injectors but i get spark. im totally confused as this is my first swap so if you can drop some knowledge it would be much appreciated!
Old Mar 12, 2009 | 07:14 AM
mouab18c1's Avatar
Default Re: HELP!!!! ls/vtec swap
check your grounds. check your distributor. ignition coil might be dead. check for blown fuses
Old Mar 12, 2009 | 07:19 AM
thefesone's Avatar
i checked all fuses, relays, my dizzy is good (tested it on my friends ride). got my ground goin to the valve cover and its good, made sure no paint at points of contact...
Old Mar 12, 2009 | 07:21 AM
mouab18c1's Avatar
was your car running fine until you swapped motors?
Old Mar 12, 2009 | 07:26 AM
thefesone's Avatar
well yes and no. it was running great til the timing belt gave out. that kind of sparked the whole swap. but some info that might help, i had a super afc in there before which has been taken out in light of a s300. we heat shrinked all the wires back to stock positions and checked for continuity on all the wires we had to repair.
Old Mar 12, 2009 | 08:35 AM
mouab18c1's Avatar
seems like its a wiring issue...double check all your wiring. and check your ecu again
Old Mar 12, 2009 | 08:46 AM
Furyof4's Avatar
Thermostat ground?
94icxhatch
Aug 12, 2013 10:02 AM
90datech
62
Jan 11, 2008 06:30 AM
Turbo_Mike
Feb 20, 2006 12:36 PM
boosted-delslow
Mar 10, 2004 06:36 AM
WickedPerform
May 14, 2001 01:40 PM
