EK9 CTR Cams in JDM B16A?
Old Mar 18, 2009 | 06:48 AM
SINISTR's Avatar
Default EK9 CTR Cams in JDM B16A?
hey guys,
whats the general opinion of having those cams installed? good/bad?
they are a little more aggressive than ITR cams on the intake...
Would springs need to be changed from stock B16A springs? what about general tuning in the ECU department? VAFC capable of doing the job??
any advice would be appreciated!
thanks
Old Mar 18, 2009 | 04:47 PM
H24A96EK's Avatar
Default Re: EK9 CTR Cams in JDM B16A?
vafc will get you by. won't see the maximum potential of the cams with it. you will be ok with the springs as long as you remain responsible with the rpms til you find more info with the spring rates and lift rates.
Old Mar 22, 2009 | 10:17 AM
240SEXY's Avatar
I have a JDM B16A with a CTR intake camshaft and a GSR exhaust camshaft. I was told the same thing about the stock valve springs and retainers. I have no idea how high the stock valvetrain will support the cam but I recommend you upgrading them. I went with a used set of ITR dual valve springs and Skunk2 retainers. But even with my stock cams and no rev limiter I've *accidentally* gone to like 9200ish a few times misshifting...lucky maybe? Do it right the first time and upgrade the valvetrain. I haven't gotten mine tuned yet. I thought it was a good upgrade from stock at the time, but am now craving for a bigger cam. I don't know how you'll feel about them after a while of having them in.
Old Mar 23, 2009 | 05:02 AM
SINISTR's Avatar
cheers boys.
do you think BLOX valve springs are ok to use? they say they are perfect for stock and aftermarket cams - considering CTR cams are stock in a B16B... is it good? Or should i look more at Skunk2 or something like that?
Old Mar 25, 2009 | 03:45 PM
H24A96EK's Avatar
really all depends if you like to tap redline everywhere you go or if you just float around in it and casually like to feel what you got responsible. two differant aspects there.
Old Mar 26, 2009 | 01:38 AM
Katman's Avatar
92+ stock B-series valvetrain can handle up to about 8800rpm before valve floating occurs. Although, I've ran up to 9000rpm (on buddyclub cams) numerous times with titanium retainers + full ITR springs while road racing when I use to have a B-series. Nothing bad has happened. B16's can easily handle high revs too.
CTR cams are the best B-series VTEC OEM cams before moving into a more radical aftermarket camshaft.
A CTR intake cam's profile has 3 degrees more duration than an 96-97 ITR intake cam.
The 00-01 ITR's use a CTR intake cam and the way to tell is by the dual engraved rings on the end of the camshaft as seen here:
So look for these markings when purchasing a used set.
Old Mar 26, 2009 | 08:41 AM
trigger_time's Avatar
hey fellas while you guys are on this subject this picture is to be a set of itr cams from a b18c5 ? from what i have redad so far is this true ? i bought a huge parts lot and plan on putting these in my b16a . are these itr b18c5 cams ?
Old Sep 8, 2009 | 02:47 PM
em1pusha99's Avatar
My vote would be yes they are. i may be wrong....^^^^
Old Sep 9, 2009 | 02:29 AM
.Manny.'s Avatar
Touching My Member
keep the redline at 8200 and you should be ok. change the valvetrain if you have the money
Old Sep 9, 2009 | 05:42 PM
letam06's Avatar
how much performance is noticable if i purchased and installed a CTR intake camshaft and a GSR exhaust camshaft in my b16a. or is it worth it to just save and buy some skunk2 tuner series cams. replacing the springs and retainers wont be a problem but i want to try to avoid redoing the whole valvetrain (at least for the time being).
Old Sep 9, 2009 | 08:36 PM
mouab18c1's Avatar
00-01 ITR cams are the same as CTR's. i have 01 ITRS in my stock gsr head i take it to 8500 everytime i run it...havent had a problem yet and its been a year..not sure if a jdm b16 could handle the redline of 8500 but im sure you can take it to 8100 with stock valvetrain
Old Sep 10, 2009 | 12:08 PM
Katman's Avatar
YES - that is a 00-01 US ITR intake cam.
Old Sep 10, 2009 | 12:39 PM
AH VTEC's Avatar
I have a Jdm B16 and I added the 00-01 ITR Cams... I Still have the stock valve trane... The car is running on a Chipped P28. The only Noticable difference is in VTEC... around 6000 RPM on up to be specific. I've had them in my car for over a year with no Problems... I still retain an 8100 RPM Redline which I have hit 3 or 4 Times with no Problem. Good Luck, hope this helps.
Old Sep 10, 2009 | 07:05 PM
letam06's Avatar
Originally Posted by AH VTEC
I have a Jdm B16 and I added the 00-01 ITR Cams... I Still have the stock valve train... The car is running on a Chipped P28. The only Noticable difference is in VTEC... around 6000 RPM on up to be specific. I've had them in my car for over a year with no Problems... I still retain an 8100 RPM Redline which I have hit 3 or 4 Times with no Problem. Good Luck, hope this helps.
awsome man. thanks for the info. i am also running a jdm b16 with stock valvetrain w/ chipped p28 as well.
what cars and years does the ITR intake camshaft and the GSR exhaust camshaft come out of? stupid question i know, sorry.
Old Sep 10, 2009 | 08:09 PM
AH VTEC's Avatar
I am Using the Both the Intake and Exhaust 00-01 ITR Cams... Its the equilvalent to the CTR Cam.
Old Sep 11, 2009 | 06:48 PM
mouab18c1's Avatar
the 00-01 ITR cams come from the 00-01 Itr's. Gsr's can be from 94-01
Old Sep 11, 2009 | 10:24 PM
thirdkill888's Avatar
yup those are itr cams
Old Sep 12, 2009 | 09:00 PM
letam06's Avatar
Alright, more specifically, whAT engines are the itr and gsr cams from. Average price. Want to purchase in the future and not get ripped off.
Old Sep 13, 2009 | 07:09 AM
Top Ramen's Avatar
Um . . . ITR and GSR engines.
Old Sep 14, 2009 | 10:30 AM
mouab18c1's Avatar
you might as well just by 00-01 ITR cams. intake and exhaust. they should be no more then 300-350. i bought mine for 280 shipped..just look around
Old Oct 21, 2009 | 07:32 AM
dj theoretic's Avatar
True, I have CTR cams Intake and Exhaust on my B16a JDM, so Far I had them for about a year and no problems ( Knock on wood ). I usually don't go over 8000RPM because I don't race. Over all good upgrade!!!!
Old Oct 21, 2009 | 07:37 PM
Katman's Avatar
don't be skurred to rev past 8K..."R" cams and stock b16 VTRAIN can handle up to 8600rpm no problem.
Old Oct 22, 2009 | 03:42 PM
Double_Trouble_99's Avatar
yes!! the search button finally worked for me!!lol found what i was looking for woo hoo!!
03EM2guy
28
Nov 16, 2011 11:13 AM
HiChanDC2R
19
Oct 14, 2010 04:40 AM
F4i
Apr 16, 2008 01:53 PM
89s1
Oct 14, 2004 03:08 PM
SiRex91
Nov 24, 2002 10:49 PM
