D15 revs up and Down issue PLEASE HELP!!!!
Old Mar 8, 2009 | 10:44 AM
hcope316's Avatar
Default D15 revs up and Down issue PLEASE HELP!!!!
I have already replaced the Idle air control Valve and the fast Idle Thermal valve, Neither helped at all,I also checked for low coolant and vacume leaks. It is a 93 dx so I dont have a tach but I would say it bounces from 1000-2500 rpm's while at idle. Any help would be great
Old Mar 8, 2009 | 11:06 AM
srmofo's Avatar
Default Re: D15 revs up and Down issue PLEASE HELP!!!!
try bleeding the coolant system. theres a bleeder on the upper neck. there is also a line that is in between the head and intake plenum that needs to be bled. thats what is probaly causing your idle issue. Ill try to find a pic ,or maybe someone else can post it if they have it, or try searching for it
Old Mar 8, 2009 | 01:26 PM
SOHCNightmare's Avatar
Possibly a vaccuum leak around your intake mani fold gasket?? spray some ether (starting fluid) around the gasket and see if your engine revvs change at all.
Old Mar 8, 2009 | 03:24 PM
boostedjdmdc2's Avatar
yeah if you replaced both and checked coolant look for vacuum leaks
Dannyboy94
Feb 20, 2015 09:26 PM
bopbop93030
Oct 6, 2009 11:45 PM
luv2boost
Jun 2, 2008 06:33 PM
hybrid901
May 29, 2003 07:20 AM
