radiator size! half size?where to get one?
Old Feb 27, 2009 | 04:49 PM
209lsr_ly's Avatar
Default radiator size! half size?where to get one?
my turbo set up, top mount s372 twin scroll WG with fullrace dual back door IC and the piping has limited room space for a stock size EG radiator. I need a half size radiator of that a stock eg one? Where would i find one? i looked on ebay and they have them for the gokart but the inlet/outlets are to small. any ideas? HELP!
Old Feb 27, 2009 | 06:04 PM
Budhound's Avatar
Default Re: radiator size! half size?where to get one?
So you need an eg radiator? used, go to car-part.com or call a parts store and get a new one.
Old Feb 28, 2009 | 05:44 AM
209lsr_ly's Avatar
Not the thickness. I'm talking about the width
Old Feb 28, 2009 | 06:16 AM
patriot's Avatar
And you're expecting to keep the coolant temps down?
Old Feb 28, 2009 | 06:48 AM
NJIN BUILDR's Avatar
A eg size radiator is about as small as you can go if this thing is street driven.You will need to tilt or angle an eg one,or rethink your intercooler.A custom build radiator would be an option but it won't be quick or cheap.
Old Mar 1, 2009 | 03:52 PM
209lsr_ly's Avatar
No I'm not worry about the temp on the motor. Just using it for quarter mile purposes only. And the eg stock is to big for the limited spacing I have too. Guess I'll keep on looking. I'll have pic up on what I mean when my IC pippings are done.
Old Mar 1, 2009 | 05:18 PM
In that case just have a custom one built.Thae cheapest way maybe to just get a motorcycle one that fits your space and use reducers to fit the hoses.On my old engine dyno I had a box of hoses and mild steel exhaust reducers to fit any engine to the dyno heat exchanger.
Old Mar 1, 2009 | 05:44 PM
patriot's Avatar
Run nitrometh and then you wont need any coolant.
Old Mar 1, 2009 | 06:36 PM
Ls_dx's Avatar
most people just use a stock eg half rad.
KPowerSquadron
22
Aug 22, 2010 04:57 PM
94civicsi1989
Jul 23, 2009 08:15 AM
allhonda
Oct 4, 2008 11:19 AM
XzzYzzX
Apr 23, 2005 08:42 AM
