Hole in oil pan
Old Mar 10, 2009 | 03:13 PM
wyroper's Avatar
New User
Icon6 Hole in oil pan
My 97 Accord LX had a self-drilling sheetmetal screw head (with washer and rubber gasket) visible on the bottom of the oil pan.I dropped the pan and found the screw had drilled a 1/8" hole in the hollow tube of the MAIN BEARING CAP BRIDGE.Does engine oil circulate thru this tube?If not,will the hole cause a problem?
I was going to braze up the hole in the pan,but noticed the inside is coated with paint.How do yall recommend repairing it?
What kind of paint will work?
Thanks
Old Mar 11, 2009 | 03:21 AM
NW Classic Honda's Avatar
Default Re: Hole in oil pan
Just buy a new pan at the junkyard.
Old Mar 11, 2009 | 07:02 AM
jlude90's Avatar
and a new main bearing bridge
Old Mar 16, 2009 | 01:08 PM
wyroper's Avatar
New User
Can i change the main bearing bridge with the motor in place?
Do the main brg bolts need to be replaced?
Old Mar 16, 2009 | 02:52 PM
jlude90's Avatar
yes, you can change the bridge with the engine in the car
and i didn't replace the bolts, probably wouldn't be a bad idea, but for what its worth i didn't when i changed my main bearing bridge
Old Mar 16, 2009 | 03:18 PM
DonF's Avatar
You cannot change the Main bearing bridge without a A-lign hone or bore. Do not take bad advice.
Old Mar 16, 2009 | 05:48 PM
jasoncanseeoh's Avatar
Just buy a new oil pan, dude.
Old Mar 17, 2009 | 11:25 AM
wyroper's Avatar
New User
DonF, Are you saying that the main brg bridge aligns the main brg caps and therefore the main bearing bore?
Does the bridge serve as a pressurized oi reservoir/accumulator for the main brgs?
I know it is connected to the pressurized oil circuit-I blew compressed air down the passage feeding oil to the head and got a good blast of air out of the hole they drilled in my bridge.
Old Mar 17, 2009 | 02:51 PM
srmofo's Avatar
whats wrong with just filing the hole up with weld?...that is of course if you know how to do it properly, if not just let a welder fix it for ya, Im sure it will be less than another junkyard pan
Old Mar 17, 2009 | 03:42 PM
wyroper's Avatar
New User
Welding or brazing up the hole in the oil pan is no problem.Welding the hole in the bridge might be.It's cast aluminum and would have to be tigged or migged.Im thinking the heat could warp it.
Old Mar 18, 2009 | 08:20 AM
jlude90's Avatar
i was not aware that you needed to get it align honed after a change of the main bearing bridge. good to know, sorry for bad advice
preludeNApower
Aug 1, 2014 09:55 PM
NEAL FRISBIE
Mar 1, 2011 09:42 AM
streetracerjoey210
Feb 8, 2009 09:31 AM
The Dirty EJ1
Mar 19, 2008 08:58 PM
Wilky
Nov 18, 2007 09:47 PM
