95 gsr problemz!!!!!!!
Old Mar 4, 2009 | 12:18 AM
cftb16600's Avatar
Icon6 95 gsr problemz!!!!!!!
My Gsr runs fine from idle to about three-four thousand rpms then starts popping and kinda bogs down! can somebody suggest to what could be wrong??? Please?!! Changed injectors, spark plugs, wires, new timing belt, oil pump, water pump, fuel filter! and redone the timing six times and its right.
Old Mar 4, 2009 | 05:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: 95 gsr problemz!!!!!!!
Sounds like ECU/ECM may be in "limp mode".
Have you checked for codes? 94
Old Mar 4, 2009 | 08:28 AM
cftb16600's Avatar
Icon6 Re: 95 gsr problemz!!!!!!!
Is that all could be? Im thinking lik distributor or fuell pump or FPR or something it runs fine until higher rpms
Old Mar 4, 2009 | 08:41 AM
mouab18c1's Avatar
could be your distributor
Old Mar 4, 2009 | 04:48 PM
fcm's Avatar
fcm
Old Fart
It would be something to look at, seems you have checked/swapped just about everything else, have you checked to see if it throws any codes yet? 94
Old Mar 5, 2009 | 02:28 AM
dewulf92's Avatar
SAME EXACT problem i am having. with a gsr swapped 92 ls teg. i'll let u know if i find anything thing else out.
Old Mar 5, 2009 | 10:08 AM
raytownracer's Avatar
Had a similar problem with my dc2 gsr. Try changing your IM gasket (Hondata is the best)
Old Mar 5, 2009 | 10:22 AM
fergy016's Avatar
Have you done anything to the engine lately in other parts?
Fuel Filter replaced in the past 60k miles or 4 yrs?
Do you have a cel(check engine light)?
Old Mar 6, 2009 | 10:18 PM
Mr. EF's Avatar
having same issues and its my distributor...
beatontheeznutz
Feb 19, 2012 07:52 AM
redss90
Nov 7, 2010 11:23 AM
gaz728
May 15, 2008 03:19 PM
94eh2
Nov 18, 2007 03:40 AM
Abomb
Sep 16, 2007 01:22 PM
