Help! Ripped upper control arm bushings!
Old Feb 2, 2004 | 10:28 AM
Zatar69's Avatar
Default Help! Ripped upper control arm bushings!
I've got skunk2 front upper control arms (camber adjusters) and in one of them BOTH bushings are completely torn out, causing the arm to "float" which is causing some major caster problems!
Does anyone know where to get replacement bushings for this? Any part numbers?
TIA
p.s. 97 Honda civic coupe. (so 96-00 front uca)
Old Feb 3, 2004 | 06:41 AM
Fobtions's Avatar
Default Re: Help! Ripped upper control arm bushings! (Zatar69)
i think u should give skunk2 a call directly,
Old Feb 3, 2004 | 08:42 AM
owen_the_soyboy's Avatar
you may be able to order ES poly replacements from summitracing.com if the skunk units are same length/diameter as stock
Old Feb 3, 2004 | 09:29 AM
Zatar69's Avatar
Default Re: Help! Ripped upper control arm bushings! (Fobtions)
I called Skunk2 directly yesterday and they said "Yes".
So I grabbed a stock UCA from the wreckers and I'm going to push out the bushings today.
I also noticed that the stock ones seem to be a bit beefier in how they connect than the skunk2 ones...
To Skunk2 tech support!!
DrewMD
Nov 25, 2016 01:10 PM
hondasingapore
Suspension & Brakes
Oct 15, 2009 01:14 PM
Aventuraa
13
Apr 20, 2009 11:14 AM
EnjoyTheRideDC2
Jan 10, 2007 10:36 PM
.RJ
Mid-Atlantic (Sales)
Dec 9, 2005 05:42 AM
