Code 41 for oxygen sensor, Limp mode?
Old Feb 3, 2004 | 09:35 PM
Timmay's Avatar
Default Code 41 for oxygen sensor, Limp mode?
will this CEL code 41 throw a car into limp mode, maybe causing a lower rev limiter?
this is on a 94 Del sol dohc vtec
Old Feb 4, 2004 | 05:26 AM
92b16vx's Avatar
Nope, I had 41 for a couple months, till I unlazied and fixed my o2, ran fine.
Old Feb 4, 2004 | 09:00 AM
Kataku2K3's Avatar
Default Re: (92b16vx)
Yup You're fine, you'll have that CEL but just get your oxygen sensor problem fixed and you'll be set... Your car runs in limp mode if something important goes out like your distributor sensors (CKP, CYP, TDC), running your no ECU with no ROM or a bad ROM, etc... You'll know it when you do as your car probably won't rev much above ~3500rpm...
Old Feb 4, 2004 | 02:34 PM
Timmay's Avatar
Default Re: (Kataku2K3)
it seems to be cutting out at about 7-7500 like a rev limiter. and thats the only CEL we get. gonna change the plugs and mess with the fuel a bit
91hatchproject
Mar 29, 2010 04:40 PM
ssdelsol
Sep 25, 2009 09:20 PM
hack_tc
Nov 28, 2007 11:39 PM
1.8Tities
Sep 9, 2003 02:11 PM
KENetics1
Apr 10, 2003 10:31 AM
