Yes or No with this swaybar.
Old Feb 4, 2004 | 10:45 PM
Odiedogcx's Avatar
AIRBORNE
Default Yes or No with this swaybar.
I may be trading my friend a JL Audio 12w3 for his Progress rear sway bar (part #61.1004/62.1003)
I have an 00 Si, so i'm pretty sure i already have an OEM rear. Is this mod worth the trouble? Would there be much of a difference? Thanks!
Old Feb 5, 2004 | 12:34 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Yes or No with this swaybar. (Odiedogcx)
a rear sway bar, or a bigger one in your case will make the most difference in the way car handles. Progress makes good stuff and although i do not have their ARBs i do have their springs. ARBs should be the first replacement/add-on to any suspension alteration. keep in mind your car will rotate much more with a bigger rear bar, so be prepared for that. make sure your tires are in good shape as well. loosing your tail in a turn when you had never could before is unsettling.
Stan
Old Feb 5, 2004 | 11:01 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: Yes or No with this swaybar. (Stan D)
So i should upgrade my Si sway bar, to the progress?
Old Feb 5, 2004 | 01:45 PM
Team 4R's Avatar
if you're into cornering... then, yes, upgrade......... to the progress? i dunno........
Slow_import
Suspension & Brakes
Feb 16, 2006 09:15 AM
Nisif
16
Jan 24, 2006 07:53 PM
Cuong-nutz
Suspension & Brakes
Aug 8, 2005 03:45 PM
eMpAtHy
May 19, 2005 10:09 AM
p1driftfiend
14
Feb 23, 2004 12:18 PM
