Where can i find these..
Old Feb 6, 2004 | 03:33 AM
Jmorin's Avatar
Default Where can i find these..
Where might i get those clamp things holding the rear hatch window??
Old Feb 6, 2004 | 08:47 AM
owen_the_soyboy's Avatar
Default Re: Where can i find these.. (Jmorin)
maybe a drag racing store like http://www.summitracing.com
or a jdm ***** shop like ajracing in b.c. canada
maybe even home depot
Old Feb 6, 2004 | 10:12 AM
tgreaves's Avatar
Default Re: Where can i find these.. (owen_the_soyboy)
They look like Cusco hood pins.. Are these it..
http://www.importfan.com/produ...=2680
Old Feb 6, 2004 | 11:53 AM
snoochtodanooch's Avatar
Default Re: Where can i find these.. (tgreaves)
they look like it to me...
Old Feb 6, 2004 | 02:25 PM
mrlegoman's Avatar
Default Re: Where can i find these.. (snoochtodanooch)
Are they actually touching the paint?
They look like they would scratch the paint.
Old Feb 6, 2004 | 05:55 PM
Jmorin's Avatar
That looks like it,But how did he mount these on the window???
Old Feb 7, 2004 | 05:21 AM
speedracer2kjory's Avatar
http://www.jdmhondaparts.com they have sparcos or http://www.inlinefour.com
Old Feb 7, 2004 | 10:21 PM
4inspeed's Avatar
Default Re: Where can i find these.. (speedracer2kjory)
well go out to the back of your hatch (assuming you have one), there should be a little black circle gromit type thing on each side near the bottom. right where he mounted his. you can take these off and there will be holes in the glass. , you could either drill out a hole in the existing pieces and mount that way or custom make your own piece to fit there.
but is your latch broken or something? or could you explian to me the point of these? not trying to be a dick but really, whats the use?
Old Feb 9, 2004 | 05:50 AM
tgreaves's Avatar
Default Re: Where can i find these.. (4inspeed)
Yeah the window grommets is how he mounted it.. Im guessing this is for looks.. If not then it would be alot better to just fix your latch if it is broken..
Old Feb 9, 2004 | 02:58 PM
mrlegoman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4inspeed &raquo;</TD></TR><TR><TD CLASS="quote">well go out to the back of your hatch (assuming you have one), there should be a little black circle gromit type thing on each side near the bottom. right where he mounted his. you can take these off and there will be holes in the glass. , you could either drill out a hole in the existing pieces and mount that way or custom make your own piece to fit there.
but is your latch broken or something? or could you explian to me the point of these? not trying to be a dick but really, whats the use?</TD></TR></TABLE>I would guess that you would use these if you had a Lexan window and/or a fiberglass trunk lid that do not have stock latch attachment?
Old Feb 10, 2004 | 12:51 AM
mckenzie's Avatar
srr makes them.. check the sponser's forum
JDM*addiction
May 19, 2006 11:43 AM
riceburners1
19
May 28, 2004 05:09 PM
SoCar
Jul 2, 2003 08:35 AM
