b18c into 93 EG help..
Old Feb 5, 2004 | 11:35 PM
Hybrid2Be's Avatar
Default b18c into 93 EG help..
hi. i have a 2000 gsr motor i'm putting into a 93 civic. i have the obd2 ecu. how do i go about the wiring? do i need a jumper? do i need a different ecu? sorry i didn't search.. thanks ahead of time for feedback
Old Feb 6, 2004 | 07:50 AM
c1civic's Avatar
just get the obd2 to obd1 jumper and be done with it...good luck
Old Feb 6, 2004 | 12:52 PM
Katman's Avatar
Default Re: b18c into 93 EG help.. (Hybrid2Be)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid2Be &raquo;</TD></TR><TR><TD CLASS="quote">hi. i have a 2000 gsr motor i'm putting into a 93 civic. i have the obd2 ecu. how do i go about the wiring? do i need a jumper? do i need a different ecu? sorry i didn't search.. thanks ahead of time for feedback</TD></TR></TABLE>
ok don't listen to what c1civic just spewed, he's wrong.
your car is already OBD1 so you can already stick with using an OBD1 ecu with your 00 GSR engine. But if you really want to use the GSR ecu, (1) you'll have to get the IMMobilizer removed before using it and (2) you'll have to purchase an OBD1 to OBD2b ecu jumper harness (which i sell if you're interested). But you don't have to do any of this if you find yourself an OBD1 P72/GSR ecu.
And if you're wondering about engine wiring and the onboard OBD2 engine's electronic components (injectors/distributor/alternator)...
If your GSR motor is US spec and comes with the GSR engine harness, USE IT, it's totally compatible with your OBD1 civic. A few unimportant plugs won't be used though, but the harness will work nonetheless.
Old Feb 6, 2004 | 01:38 PM
redlinetuning's Avatar
Default Re: b18c into 93 EG help.. (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
If you have an EG SI, even better, just use your stock harness, though you'll have to cut the knock sensor connector off the old harness and run new wires to the ECU. If you do have the 00 GSR harness just use that instead like Katman said.
Katman, are you with JdmHondaparts?
Old Feb 6, 2004 | 02:20 PM
Katman's Avatar
Default Re: b18c into 93 EG help.. (redlinetuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote">
Katman, are you with JdmHondaparts?</TD></TR></TABLE>
yes, I'm part co-founder of jdmhondaparts.com, but I don't run the show there, that's all Sheng. I just run the ecu reprogramming & jumper operations and keep the website maintained.
btw, its a lot easier using the OBD2 GSR engine harness instead of his 93 Si/OBD1 engine harness with this OBD2 GSR engine, as the OBD2 igntion/injectors/etc will not plug n' play with an OBD1 wire harness... whereas the GSR engine harness will. He'll just have to make sure his car is wired for vtec depending on what 93 civic model he owns.
Hybrid2Be
Dec 19, 2003 03:54 AM
hondaspeder
Sep 9, 2003 09:59 AM
Fuster_Cluck
May 27, 2003 08:39 PM
Fuster_Cluck
Feb 21, 2003 01:14 AM
Todd00
Oct 5, 2001 12:41 PM
