D15 idle question...please help?
Old Feb 4, 2004 | 06:44 PM
vxhatch02's Avatar
Default D15 idle question...please help?
I have a 95 VX hatch with stock motor and my idle is messed up. Here s what it does it irractically idles from 500to 1500 rpms when idling. I checked the pcv valve "ok", we have check iacv "ok", i have unplugedd the ecu fuse, then somebody told me to close the idle screw quarter turns till till the idle stops jumping and i did that and it stoped is this OK?, Or Is there something else i should do??? Please help i just got the car and this is the only thing wrong with it.
Thanks
Old Feb 4, 2004 | 08:35 PM
hondatim's Avatar
Default Re: D15 idle question...please help? (vxhatch02)
sounds like you just need to set base idle to spec. Try doing a search. I have detailed out the entire procedure many times.
Good luck!
b20eg9daddy
Oct 25, 2008 12:37 PM
manyakiexpi
Feb 18, 2006 11:45 AM
diLUDEd
Aug 24, 2002 09:55 AM
